I have bad result in printing when using windows arabic fonts like arabic transparent or arial ( not Acad fonts)... they appear well on screen but the scrabbled when printed .... any idea how
Hi
This is beacuse of the plotter/printer settings.
in Plot dialog box
1- Select the Printer/Plotter then
2- Properties
3- Device and Documnent Settings Tab
4- Click on (+) next to Graphgic then True Type Text
5- Choose True Type as Graphic
6- OK
7- This option for this job only
8- This option to create a perminant proter settings to use next times
9- Ok to go back to Ploting dialoge box
Regards
I don't know why it didn't workswith me ...I've attached the pdf and the original finel maybe I'm missing something
Hi
This happen because you used English font I think you do just alt+ lift shift and write Arabic , So please used this font for Autocad
it works with me
see attached
any way try to use the arabic fonts which e.mounir attched
to use the fonts files
close autocad
copy and paste this 2 files in autocad font folder
for ex. C:\Program Files\AutoCAD 2007\Fonts
then create a new textstyle and coose this font
PS. I have more font files if you want I'll send you.
Hasan
tryout this solution
1.) Close all programs
Go to Control panel| Regional and language settings
Languages tab
Select "install files for complex script and right to left languages (including Thai)
Requires a reboot
and in printer properties Choose True Type as Text
Its installed (see attached)
eeeemmmmm
- did you create a new PC3 file for the printer and use it?
PS: at first reply in attached image In step no 5 choose True Type as a text not as a Graphics
- Try to print the same file using another PC.
Hasan
It finally works .. thanks ...
ps. for my HP 500 plotter i had to send file as bmp map not sending it directly to plotter ....
Thanks a lot... it's a big help to find the solution on my problem...
