We are having issues importing a Sketchup file into Revit and changing the materials to revit ones for rendering.
We have tried:
(1) Modelling in Sketchup using components for things like walls, then putting them on a layer and importing into Revit. If we try this method, and alter the Imported Objects material for that layer, it still renders in a default white material. This is our preferred way of working in sketchup.
(2) If we model in Sketchup and dont use components (i.e. use groups instead) we can change the materials in Revit. This is not how we generally work in sketchup.
Is this a bug/known issue with Sketchup import?
