Thread: XML Metadata
    28
    Default XML Metadata
    Is there any way to "imbed" and XML metadata in a drawing?...or...does anyone have any advice on utilizing the XML functionality, in regards to metadata?
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,447
    Default Re: XML Metadata
    The "Meta" element in an XML file is confusing, at first. It has no "Content" but it ahs attributes that you can define. One of them is Content and some of the others are Id, Name,Skip-Content,Pics-Label and Title. You can add these in a normal text editor easily, or in your stylesheet. If you look at the Drawing Properties, this is the Metadata that is embedded into the drawing already, Author, Date cretaed and so on. So if you want to add this info to your drawings, run the drawingprops command and add what you want, it even allowsw for Custom properties.
  1. Replies: 0
    Last Post: 2015-08-07, 05:38 PM
  2. Extracting Metadata from a .DWG
    By nicholas.amphlett in forum CAD Management - General
    Last Post: 2009-12-07, 05:41 PM
  3. Synchronized (FTP) DWG files lose their metadata
    By Duncan Lithgow in forum Networks
    Last Post: 2008-09-25, 08:54 PM
  4. Change metadata (Sheet Properties) for DWFs
    By Andrew Dobson in forum Design Review - General
    Last Post: 2008-08-14, 11:59 AM
  5. Revit's Next Big Thing - Metadata
    By mibzim in forum Revit Architecture - General
    Last Post: 2007-08-22, 05:25 PM
