Thread: MDT 6 Dialog Boxes
    2005-04
    Default MDT 6 Dialog Boxes
    Hopefully someone will be able to help with a small problem that has just cropped up whilst using Mechanical Desktop 6.
    The problem is that on clicking an icon that usual brings a dialog box into play, the box does not appear and the instructions for the relevant action appear in the text lines on the bottom of the screen.
    I am hoping that someone can point me in the right direction of the setting that needs to be reset in order for the dialog boxes to reappear when required.
    Please accept my apologies if this enquiry is in the wrong section of AUGI - first time user here.
    Many thanks in anticipation
    13,657
    Default Re: MDT 6 Dialog Boxes
    Hi
    Please note I've *moved* this thread from the CAD Mgmt. General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,657
    Hi
    Take a look at the following thread -
    System Variables
    Have a good one, Mike
    2002-07
    16
    CMDDIA needs to be set to 1.
    Member sanjay_yallure's Avatar
    2004-08
    India, Ahmedabad
    10
    FILEDIA also needs to be set to 1.
  1. MEP Dialog boxes
    By gugg in forum AMEP General
    Last Post: 2012-05-04, 07:06 PM
  2. Dialog boxes
    By BCrouse in forum ACA General
    Last Post: 2006-01-10, 12:59 PM
