Thread: Parent/Child Component Difficulties
    2016-01
    8
    Default Parent/Child Component Difficulties
    Using Acad Electrical 2009 and trying to build schematic component symbols by editing AcadE symbols and doing a "save as" to our company part no. as the name. When doing this for parent/child components, I am not able to get the parent component to call and use the child component as it should. For instance, the parent 3 pole circuit breaker in AcadE is called "Hcb1" and when inserted into schematic it pulls in two additional child CB's called "Hcb2". My custom 3 pole CB's don't do that. My custom parent component populates what should be two more child components with parent components so I end up with 3 parent blocks. I have used the TAG1 attribute in the parent and the TAG2 in the child, but my child object doesn't hold the TAG2 setting. It reverts back to TAG1. Yet the original block that I did the "save as" from holds the TAG2 setting. I am out of ideas and trial and error efforts. Is there an expert out there that can tell me what I am missing? Thx in advance!
    2010-04
    39
    Default Re: Parent/Child Component Difficulties
    I would suggest that you use Symbol Builder to create your blocks vs. the "save as" method. When you run Symbol Builder you can open an existing component and then "save as" when you get to the Save Symbol dialog.
    2010-04
    39
    Also, when inserting some componets from the Icon menu a command is executed to achive what you are looking for. You will need to setup your new componet(s) in the Icon menu using the Icon Menu Wizard with the approriate command.
    I could stop if I wanted to RenataP's Avatar
    2004-02
    Flint, Michigan, USA
    370
    Quote Originally Posted by tshaffer View Post
    ...For instance, the parent 3 pole circuit breaker in AcadE is called "Hcb1" and when inserted into schematic it pulls in two additional child CB's called "Hcb2". My custom 3 pole CB's don't do that. My custom parent component populates what should be two more child components with parent components so I end up with 3 parent blocks. I have used the TAG1 attribute in the parent and the TAG2 in the child, but my child object doesn't hold the TAG2 setting. ...
    Tshaffer,
    Are you still having issues with the parent/child symbols?
    If so, could you attach your two blocks for me to review, this would help pinpoint the problem. You might be missing an attribute or just a naming change. What is the naming convention for your parent and child blocks?
  1. Remove Child from a Parent Style
    By andybosch in forum AutoCAD Civil 3D - General
    Last Post: 2013-12-11, 06:09 PM
  2. Quicker insertion of Parent/Child components?
    By tshaffer in forum AutoCAD Electrical - General
    Last Post: 2011-07-29, 12:13 PM
  3. Parent and Child relation
    By CADone in forum Inventor - General
    Last Post: 2008-11-24, 07:29 PM
  4. ONE PARENT-MULTI CHILD
    By suren.patel in forum AutoCAD Electrical - General
    Last Post: 2008-07-08, 12:06 AM
  5. Parent-Child Textmask
    By cochrajc in forum AutoCAD General
    Last Post: 2005-09-23, 09:55 AM
