Results 1 to 10 of 10
Thread: ASD2011-Reinforcement Module-BUGS-Please need hotfix
    2015-09
    38
    Default ASD2011-Reinforcement Module-BUGS-Please need hotfix
    ASD2011-Reinforcement Module:
    1- Spliced bars shown in section (created by ASD2011) of reinforcement surface distribution is not aligned. (Please see attached JPG file Plan-section)
    2- The measured concrete cover of the spliced bars shown in section is incorrect (not equal to the value which is defined in the cover field in Surface reinforcement-bars window).
    3- Bars will be located outside the section when section moved. (Please see attached JPG file Plan-moved section)
    This is very serious mistake.
    Regards.
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    Default Re: ASD2011-Reinforcement Module-BUGS-Please need hotfix
    umm....this USER group cannot generate a hotfix.
    I would suggest you log a support request, so that Autodesk gets this info.
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    2015-09
    38
    Quote Originally Posted by Katika View Post
    As Autodesk said in their web site, they consider the issues created by AUGI members.
    However, I did one support request.
    In ASD2010 they (Autodesk) issued a lot of SP's and HF's based on the fatal errors reports and based on the problems shown by AUGI members. One of my posts shows how to avoid some fatal errors. So, perhaps there is someone is facing the a/m subject and he has ideas or tricks to share.
    Thank you
    Regards,
    2004-07
    Perth Australia
    736
    The question is fine, just that you are asking for a hotfix in your title
    Kathy Taylor
    TaylorCAD
    2015-09
    38
    There is no effect after applying Service Pack SP1.
    The problem still exist.
    2009-10
    22
    I have made a support request for these issues and they have registered it for correction.
    2015-09
    38
    There is no effect after applying Service Pack SP2.
    2015-09
    38
    Angry Re: ASD2011-Reinforcement Module-BUGS-Please need hotfix
    The same problem still exists in ASD2012. !!!!!!!!!!!!!!!!!????????????
    2015-09
    38
    In ASD2012, There is no effect (regarding the main spliced bars issue) after applying Service Pack SP2. The problems still exist.
    2015-09
    38
    Thumbs up Re: ASD2011-Reinforcement Module-BUGS-Please need hotfix
    After applying SP3 (with HF1 and HF2) on ASD2012
    Finally, it is solved. Well done, many thanks to Autodesk development team of ASD.
    Best regards,
    Abbakeer
  1. 2013 Changing direction of reinforcement in provided reinforcement module.
    By ronny_raygun371629 in forum Robot Structural Analysis
    Last Post: 2013-12-03, 12:33 PM
  2. Replies: 3
    Last Post: 2011-05-23, 01:08 PM
  3. Features to be included in ASD2011-Reinforcement Module
    By abbakeer in forum AutoCAD Structural Detailing
    Last Post: 2009-11-19, 02:00 PM
  4. Any UK Users Using The Reinforcement Module?
    By allan_bim in forum AutoCAD Structural Detailing
    Last Post: 2009-11-05, 06:51 PM
