Thread: The ability to create PDF when checking files into Vault
    2009-01
    Default The ability to create PDF when checking files into Vault
    Hello,
    I would like to see the ability of when checking in a file if you could have the option to create either a DWF or PDF or both at the same time. Even though DWF is the CAD standard, PDF should be an option as well.
    Regards,
    Imran
    2006-10
    8
    Default Re: The ability to create PDF when checking files into Vault
    You've got my vote! You just can't force clients to use dwf. And even though dwf is probably better than pdf in many ways, I need to give the my clients what they want.
    2012-03
    I would like to thank you for sharing your thoughts and time into the stuff you post!!
    2012-07
    This feature can be used to create a link between M-Files and a scanner . Every file version created a copy of the file in the Vault regardless of if the file changed .
  1. Replies: 0
    Last Post: 2012-12-10, 01:36 PM
  2. Replies: 0
    Last Post: 2011-12-09, 02:57 PM
  3. checking files out of vault
    By jlucas in forum Vault - General
    Last Post: 2009-05-29, 01:52 PM
  4. Checking into vault
    By jenniferchavez in forum Vault - General
    Last Post: 2008-04-25, 08:50 PM
  5. Filter creation of DWF files When Checking Files into Vault
    Last Post: 2006-05-19, 02:29 AM
