Thread: removing items from list
    2012-03
    4
    Default removing items from list
    Hello all,
    So I have been tasked with setting up something for back fixing layers. at the end of all this I plan on using the "laytrans" command to have the user decide what layers they want transferred. A corrected template is already provided and I know what layers should exist in the drawing, but I need to provide a list of layers that don't belong. So first thought was to use this
    (setq lay (tblnext "LAYER" T))
    (while lay
    (setq lay_lst (cons (cdr (assoc 2 lay)) lay_lst)
    lay (tblnext "LAYER")))
    to grab all my layer names. This is functioning as I expected but how do I remove the good layers from this list by their name? Thanks for the help in advance!
    5,766
    Default Re: removing items from list
    Perhaps these will help....
    _GetLayers:
    (defun _GetLayers  (/ layerNames)
      ;; Example: (setq myLayerList (_GetLayers))
      (vlax-for oLayer
                (vla-get-layers
                  (vla-get-activedocument
                    (vlax-get-acad-object)))
        (setq layerNames (cons (vla-get-name oLayer) layerNames)))
      (vl-sort layerNames '<))
    _GetLayers (alternative):
    This adaptation supplies the sub-function with the ActiveDocument Object as an argument
    (defun _GetLayers  (acDoc / layerNames)
      ;; Example:
      ;; (setq myLayerList
      ;;        (_GetLayers
      ;;          (vla-get-activedocument (vlax-get-acad-object))))
      (vlax-for oLayer  (vla-get-layers acDoc)
    _RemItems:
    (defun _RemItems  (removeList  sourceList / newList)
      ;; Example: (_RemItems '("B") '("A" "B" "C"))
      (setq newList sourceList)
      (foreach item  removeList
        (setq newList (vl-remove item newList)))
      newList)
    ** Note - The sub-functions above require that (vl-load-com) be loaded prior to calling.
    HTH
    Last edited by RenderMan; 2012-05-02 at 03:08 PM. Reason: Added _GetLayers (alternative)
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2012-03
    4
    You sir, are my hero for the day! Command is working perfectly!
    5,766
    Quote Originally Posted by mixted570595 View Post
    That is kind of you to say; you're welcome.
    5,766
    I've added _GetLayers (alternative) to my previous post.
    2015-11
    Jo'burg SA
    4,512
    You could also simply have tested inside the while loop if the layer name matches to another list. E.g.
    (setq lay (tblnext "LAYER" t))
    (while lay
      (if (not (member (setq lname (cdr (assoc 2 lay))) standard_layer_names))
        (setq lay_lst (cons lname lay_lst)))
      (setq lay (tblnext "LAYER")))
  1. Removing the double list pairs
    By Ehsan in forum AutoLISP
    Last Post: 2012-07-16, 03:47 PM
  2. Removing items from an install dwg
    By robert.pickeral in forum CAD Standards
    Last Post: 2008-07-03, 01:28 PM
  3. Wish List items
    By The Monk in forum Revit Architecture - Wish List
    Last Post: 2005-07-09, 03:02 AM
  4. Removing Items from a Design Option
    By pashley in forum Revit Architecture - General
    Last Post: 2005-03-29, 12:57 AM
  5. Removing duplicate strings in a list
    By whdjr in forum AutoLISP
    Last Post: 2004-06-09, 05:40 PM
