Results 1 to 1 of 1
Thread: DV500-2: Using Autodesk 3ds Max and Autodesk VIZ in Architectural Renderings
Threaded View
Autodesk University DV500-2: Using Autodesk 3ds... 2013-05-05, 02:51 AM
    2012-11
    3,030
    Default DV500-2: Using Autodesk 3ds Max and Autodesk VIZ in Architectural Renderings
    Instructor: Dwayne D. Ellis
    Class Description: This extended lecture session is designed for CAD professionals and 3D artists using Autodesk 3ds Max and/or Autodesk VIZ, and want to elevate the level of realism in their interior architectural renderings. This presentation will cover the rendering process from beginning to end, with specific detail in the area of speed and quality optimizations. Emphasis will be placed on efficient workflow, scene set up, GI lighting, surface shaders, rendering, and post-process image enhancement. If you want to bring your interior architectural renderings to the next level, this class is for you.
  1. Replies: 0
    Last Post: 2013-04-17, 04:19 AM
  2. Replies: 0
    Last Post: 2013-04-09, 02:21 AM
  3. Replies: 0
    Last Post: 2013-04-08, 08:38 PM
  4. Replies: 0
    Last Post: 2013-03-30, 02:04 AM
  5. Replies: 9
    Last Post: 2007-11-08, 01:00 AM
