Page 6 of 6 FirstFirst ... 23456
Results 51 to 56 of 56
Thread: Better Revisions,Addendums 8.5x11
  1. #51
    2010-06
    Northern California
    6
    Default Re: Better Revisions,Addendums 8.5x11
    I downloaded and modified but I can't get it to print correctly... Perhaps I changed something while editing. See attached.
  2. #52
    2013-11
    Portland, Oregon
    OK. We've figured out how to get these sketch titleblock overlays to print correctly.
    The first step is to make sure the masking region (actually a solid white filled region surrounding the sketch area) is a very large square. We use 4'x4' to make sure it completely covers the sheet underneath. Make sure the extents of this massive masking region is centered exactly on your sketch titleblock (this will ensure proper printing later). The solid filled region and titleblock should both be in the same family.
    Make sure the Print Range is set to "Current window" (not "Visible portion of current window").
    Make sure under Settings that Paper Placement is set to "Center". With the large white mask being the outermost geometry, Revit will center to that, meaning your sketch will center on the printed layout.
    Make sure Zoom is set to 100% (do not fit to page).
    The resulting print will center the sketch titleblock on the page and print at true scale.
    It would be great if we could find a way to place these sketch titleblocks in the Project Browser in such a way that their numbering sequence is not only viewable, but also if they could be recalled easily (like a Go to View type of command). Making them Groups will probably work for now, but it doesn't seem to offer much besides creating a running list in the Browser. Even having them feed to an internal schedule with their various parameters reporting would be a huge help (perhaps listing Sketch #, Sketch Name, Date, Scale, and perhaps most importantly, which sheet they're placed on). For now I think we'll just be hiding the sketch titleblocks once the PDF of the sketch has been generated. We'll have to refer to the PDF to determine what the referencing sheet for the sketch is if we happen to need to find it again.
  3. #53
    2013-06
    I have tried using this family in 2013. The titleblock shows up over the drawings, but the masking region does not mask anything, it is clear. Suggestions?
  4. #54
    2007-09
    I have just started as BIM manager at a firm and am setting these titleblocks up. I am having trouble getting the image to show up in front of the masking region. I have tried copy to clipboard and repaste a raster image, placing it in a detail group, creating a generic annotation out of it....nothing is working. Is there something I am missing?
  5. #55
    2007-09
    I gave up and just cut a hole around my image logo. it works just fine.
  6. #56
    2018-04
    VOLS FAN STUCK IN NOTRE DAME
    30
    Quote Originally Posted by dbaldacchino View Post
    With Structural drawings, this approach isn't ideal. We use this mostly with Architectural and MEP drawings as there are other things (room numbers, door numbers) to help the viewer get their bearings! But for Structural drawings, the only cue is the grid bubble. Our Structural group duplicates views as dependants and crops them as required for issuing revisions.
    I was told not to use duplicate views as dependents but not told why. I see this so far to be the easiest way for our firm however this is our first project and want to get it right.
  1. Track Drawing Issues other than Revisions in Revisions Block
    Last Post: 2014-10-22, 06:34 PM
  2. Addendums
    By KGC in forum Revit Architecture - General
    Last Post: 2008-09-23, 02:42 PM
  3. Handling Addendums
    By jmessner in forum Revit Architecture - General
    Last Post: 2006-10-11, 02:34 PM
  4. Schedules on multiple 8.5x11's
    By matthewh.104177 in forum Revit Architecture - General
    Last Post: 2006-04-27, 09:17 PM
  5. 8.5x14 is cut to 8.5x11
    By Glenn Pope in forum AutoCAD Plotting
    Last Post: 2005-03-07, 09:45 PM
