Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Stair Path Arrow partially hiding behind tread
  1. #11
    Default Re: Stair Path Arrow partially hiding behind tread
    No I mean it literally stopped working after a few minutes. One moment all was fine, but after half an hour of continuing in the model (not worked on the stairs though!) the arrowhead was hidden again. I checked the view settings risers/treads are off.
  2. #12
    2014-12
    15
    It seems to be a bit hard to tell what's going on not seeing the actual model. I would play with other visibility parameters under VV>Stair. See if that can fix it..
  1. 2014: Stair path arrow getting clipped
    By chrise.68617 in forum Revit Architecture - General
    Last Post: 2015-09-21, 02:36 PM
  2. Stair Tread
    By kathey1 in forum Revit Structure - General
    Last Post: 2011-03-24, 09:59 PM
  3. stair tread.
    By Bluefairy in forum Revit - Student Support
    Last Post: 2010-08-29, 08:56 PM
  4. Stair top tread
    By rayf.141574 in forum Revit Architecture - General
    Last Post: 2007-06-22, 06:44 PM
  5. Stair tread design
    By Mark Vorstenbosch in forum Revit Architecture - General
    Last Post: 2006-04-18, 01:30 PM
