Thread: AutoCad Sheet set manager missing xrefs
    2015-11
    9
    Default AutoCad Sheet set manager missing xrefs
    We have three cad people in the office. No common server. we use external drives to backup our work. when we are working on the same project, we copy the files to our desktops. One person creates the sheet set, and starts the drawings. In the life of the project, the other two people might need to work on the drawings. The xrefs do not show up and is shown as absolute paths. I read that it does this because the model views were created on a different drive, even though the relative path might be the same. other than a third-party app, is there a work around for this? So that we do not have to keep re-referencing the xrefs?
    thank you!
    Cairo - no, not Illinois
    5,070
    Default Re: AutoCad Sheet set manager missing xrefs
    quit working on local files? set up a NAS or designate a pc to act as a file server.
    in the upper right corner
    3,549
    Yes what cadtag said, also you should be using "relative paths" for everything with a common file structure/naming, so no matter where it is it will find it.
    2015-11
    9
    Thank you! We are in the process of setting up the server
  1. 2011: AutoCAD 2011 Sheet Set Manager defaults fields to previous sheet set
    By Hatrick007 in forum AutoCAD Sheet Set Manager
    Last Post: 2016-05-06, 04:09 PM
  2. Current Sheet (Set) Custom in Sheet Set Manager
    By Havoc501 in forum AutoCAD Fields
    Last Post: 2012-10-04, 03:41 PM
  3. Check box to have newly created sheet set open in sheet set manager
    Last Post: 2012-01-25, 04:07 PM
  4. Sheet Set Manager can't open Sheet Set File
    By mikemck in forum AutoCAD General
    Last Post: 2010-11-15, 08:48 PM
