Thread: Change the text location for the interior elevation marker
    2014-12
    BC, Canada
    10
    Default Change the text location for the interior elevation marker
    Hi,
    I am wondering if I can change the location of the text of the interior elevation markers (see screenshot). I am running into a problem with space; for example in this small bathroom, the text locations for 7A,7B,7C,&7D are encroaching into my walls and fixtures. I don't like it. Also, I want the whole elevation symbol smaller, I don't need it taking up so much room. It seems 1/2" is my only option ~ can I change it to 1/4"?
    2001-12
    Irvine, CA
    7,567
    Default Re: Change the text location for the interior elevation marker
    Yes, but the family is complicated. It is made up of two families, one that is nested in the other. Each arrow is a separate entity. The parent (stock) family is Elevation mark Body_Circle.rfa and the nested is Elevation Mark Point_Circle. You need to revise the text/labels used in the nested family. See how far that gets you. Scale will be a factor. You'll get it right for this view scale and then in another they might end up too close, overlapping.
  1. elevation marker location to be adjustable on different views
    Last Post: 2013-11-18, 10:30 PM
  2. 2013: elevation marker related to specific elevation view
    By Ning Zhou in forum Revit - API
    Last Post: 2013-02-22, 02:07 AM
  3. Interior Elevation marker
    By thomasf in forum Revit Architecture - General
    Last Post: 2008-04-23, 01:30 PM
  4. Interior elevation Marker
    By rtrollmann in forum Revit Architecture - General
    Last Post: 2008-01-31, 08:46 PM
  5. Access the Marker Location of an AECC_Point in Map 3D 2005
    By cgerhardt in forum VBA/COM Interop
    Last Post: 2007-04-26, 05:42 PM
