Thread: Can I offset structural footings from center?
    2002-03
    Sacramento Ca.
    424
    Default Can I offset structural footings from center?
    By default, when adding bearing footings, they center on the concrete wall above which is not the typical preference in the field. Is there a way to offset my bearing footings from center to favor the inside of the foundation?
    Thank You
    in the upper right corner
    3,508
    Default Re: Can I offset structural footings from center?
    Quote Originally Posted by vanderloo5 View Post
    Thank You
    Yes you can, you tweak the "Eccentricity", normally it's zero when centered, but you add + or - values and it offsets the center of the wall.
    2002-03
    Sacramento Ca.
    424
    Thank You tedg. That's what I needed.
    2002-09
    Madison, WI
    5,688
    You can also look at a retaining wall footing where you can define the toe and the heel.
    Just another way to think about it offset footing.
  1. Replies: 0
    Last Post: 2014-12-15, 08:28 AM
  2. Replies: 0
    Last Post: 2014-12-13, 09:25 PM
  3. Attaching Structural Columns to Footings
    By Heitman Architects in forum Revit Architecture - General
    Last Post: 2006-10-02, 03:46 PM
  4. Structural/raft footings
    By Adam Mac in forum Revit Architecture - General
    Last Post: 2006-09-20, 04:03 AM
  5. Can wall footings wrap?
    By jrichardson in forum Revit Structure - General
    Last Post: 2005-11-03, 12:21 AM
