Thread: Vehicle Tracking upgrade alert
    2007-07
    Minnesota
    77
    Default Vehicle Tracking upgrade alert
    Okay – here’s the setup. We are currently using both Civ 3D 2018 and 2020 for active projects. A team member was bouncing between projects, and inadvertently worked on a 2018 version project using 2020. A number of files - model and sheets - were modified.
    We are now seeing the Vehicle Tracking update alert all over the place. We have tried a number of suggestions from the interwebs – PURGEVEHICLETRACKING the most obvious, but the alert is still prevalent.
    Looking through the forums here, and on AutoDesk, there doesn’t seem to be much else. The above-mentioned Purge command doesn’t seem to be working – I run the command, it thinks, looks like it does something, then tells me I have to save, shut down C3D, and re-open to complete. Yet, in the reopening, it still displays the alert approximately 6-8 times.
    I’m not seeing anything recently posted about this, so maybe there is some fix available, or another command that might work better. I’ve tried backsaving from the ‘corrupted’ 2020 files, and reopening, but – again, same thing. It’s too late in the design process to force a complete upgrade, as well as the contract states using 2018 version.
    I’d rather not have to restore from backups from 2+ weeks ago.
    Anything?
    9,830
    Default Re: Vehicle Tracking upgrade alert
    Quote Originally Posted by magnusonzach View Post
    Well, there is no way to really tell the difference between a drawing edited in Civil 3D 2018 and one edited in Civil 3D 2020, except for the VT garbage that you now have.
    I guess this is what is limiting you from just continuing the work in 2020?
    Suggestion: Call your reseller and make them work on this problem for you. They have access to back door support @ Autodesk that we don't.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,174
    How many xrefs are attached to the drawing showing this behavior? All attached drawings with this problem will cause that warning to pop-up. Run the PURGEVEHICLETRACKING in all xrefs. That should clear it up. You might also try the data referenced drawings also.
    2007-07
    Minnesota
    77
    Well, after a lot of trial and error - I think I have this worked out. I needed to first make a copy of each of the files and open that one (xxx - Copy.dwg). Then after I ran the PURGEVEHICLETRACKING command, I did a Save-As over the "real" version. It's not very clear in all the documentation that you need to do the Save-As in order to make the Purge stick.
    I also had to clean out the xrefs, as there was one that I wasn't aware of influencing a whole bunch. I had cleaned up the sheets, but because of the xref, it was causing it to pop back up. Such a mess.
    Thanks!
    5,745
    It's been a long time since I started this thread:
    https://forums.autodesk.com/t5/civil...y/td-p/8051334
    If memory serves, there's an "SVY_VEHICLETRACKING_DATA" dictionary created by simply opening in newer version (that shouldn't be created until user invokes an AVT command), that stores a DrawingSettings entry... If no AVT data is needed to be retained in that drawing, that Dictionary can be removed programmatically via AcadDoc.lsp, externally via ObjectDBX, etc to quickly 'clean' multiple drawings.
    You can also create a Script file to invoke the PURGEVEHICLETRACKING command and selectively employ Core Console on individual drawings in parallel:
    https://forums.augi.com/showthread.p...=1#post1339054
    HTH
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    9,830
    That is some good stuff right there ^^^^^^^^^^^
    Thanks @BlackBox!
  1. 2016: Vehicle Tracking Verses Autoturn?
    By Liamnacuac in forum AutoCAD Civil 3D - General
    Last Post: 2016-11-30, 06:49 PM
  2. 2014: Vehicle Tracking
    By rmk in forum AutoCAD General
    Last Post: 2015-03-05, 06:34 PM
  3. 2014: Autodesk Vehicle Tracking
    By MCS in forum AutoCAD Civil 3D - General
    Last Post: 2014-05-01, 08:41 PM
