Thread: Ditch Profiles
    2010-06
    5
    Default Ditch Profiles
    Is there a method in Civil 3D where one can create a profile for a ditch flow line to follow while maintaining a set side slope for that ditch?
    There would need to be multiple profiles along a project at various stationing and left or right of the center. The offset from center would most likely vary along the project while maintaining a constant side slope.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Ditch Profiles
    You can create profiles for pretty much any linear type object.
    Your assembly assigned to the specific corridor section would need to have a LinkSlopeToElevation type sub-assembly. You could then target the "ditch" profile. To maintain the slope, the horizontal placement of the ditch would meander as needed.
    Arizona
    2,478
    one might want to look into an OFFSET within their assemblies, and attach the desired ditch section using generic links...
    and or explore use of CONDITION assemblies to decide what ditch, and or side slopes should be applied based on the conditions at the ditch location
    2010-06
    5
    I am not looking for a specific offset distance. The slope and the profile elevation would determine that. I believe that the LinkSlopeToElevation sub-assembly, brought to my attention by Opie is what I am looking for.
    2015-10
    Have you considered using a target surface for establishing the slope for your ditch? Your target surface would be as offset from to centerline (inside and outside) so as to present a target for your sub-assembly for your design surface. You'd usually only need one target surface since your targets wouldn't be overlapping in most scenarios.
  1. Basic side slope cut ditch
    By tim_newsome in forum AutoCAD Civil 3D - Corridors
    Last Post: 2010-04-01, 02:58 PM
  2. Ditch Depth
    Last Post: 2009-11-22, 08:08 PM
  3. Automatic ditch cut and fill
    By sleonella in forum AutoCAD Civil 3D - Sections
    Last Post: 2009-08-21, 03:30 PM
  4. ditch subassemblies
    By kwdsku in forum AutoCAD Civil 3D - General
    Last Post: 2005-10-27, 08:00 PM
  5. Stange Elevation ditch
    By bourgeli in forum Civil 3D - Civil Design Companion - General
    Last Post: 2004-12-03, 04:42 PM
