Results 1 to 9 of 9
Thread: Adding Sheet Layouts to a tool palette
    2003-12
    45
    Default Adding Sheet Layouts to a tool palette
    Is there a way to add layouts from various drawings to a tool palette? I realize design center can be used to import layouts.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Default Re: Adding Sheet Layouts to a tool palette
    You can create a command string to import a layout from another drawing. The command is LAYOUT with the TEMPLATE option and you would need to supply the filename and layout name for the source drawing and layout you want to import.
    2003-12
    45
    If i had layout in a drawing located at ...L:\1 - SITE DEPARTMENT\3 - CAD\1 - C3D Template\Civil Sheet Templates\civil3d_XREF_DREF.dwg, what would that process look like?
    2002-01
    jUSt Here (a lot)
    9,196
    Is this for full AutoCAD and not AutoCAD LT? If so, then you could use autolisp in your command, which could look like the following:
    (command "_.layout" "Template" "L:\\1 - SITE DEPARTMENT\\3 - CAD\\1 - C3D Template\\Civil Sheet Templates\\civil3d_XREF_DREF.dwg" "Layout1")
    In AutoLISP, you will need to double the back slashes between folder names or replace each with a forward slash.
    Also, remember to change Layout1 to the specific layout name you are attempting to import.
    2003-12
    45
    Not sure how to get this to the palette. Would i just create a new command from the command list and add your string to the macro line under properties?
    Tallahassee, FL USA
    3,686
    If you need Page Setups added to plot those layouts as well Lee Mac's Steal from Drawing works well http://www.lee-mac.com/steal.html
    ^C^C^P(Steal "Template" "L:\\1 - SITE DEPARTMENT\\3 - CAD\\1 - C3D Template\\Civil Sheet Templates\\civil3d_XREF_DREF.dwg" (list (list "Page Setups" (list "11×17" "11×17 PDF"))(list "Layouts" (list "Layout1" "Layout2"))))
    You would need to replace both the layout names and the Page Setup names.
    To import them with AutoCAD LT without lisp your macro would have to turn the system variable FILEDIA off first as in
    FILEDIA 0 _.LAYOUT TEMPLATE "L:\\1 - SITE DEPARTMENT\\3 - CAD\\1 - C3D Template\\Civil Sheet Templates\\civil3d_XREF_DREF.dwg" "Layout1" FILEDIA 1
    then resetting FILEDIA afterwards.
    2002-01
    jUSt Here (a lot)
    9,196
    There is a palette from the out of the box tool palettes titled "Command Tool Samples". On that palette, there should be a tool labeled "VisualLisp Expression". You can copy that tool to your clipboard and then paste into a new palette. From there, you should be able to edit the tool's command sequence to similarly match the code provided in this thread.
    2003-12
    45
    Thanks for the aid. I have successfully created the palettes with the desired outcome!!! Which leads me to an additional question...I am creating a new command to add to a custom toolbar. It will run a lisp routine located in the folder - L:\1 - SITE DEPARTMENT\3 - CAD\5 - LSP files\demo.lsp. What would the verbiage on the macro line look like ?
    2002-01
    jUSt Here (a lot)
    9,196
    Is the AutoLISP routine already loaded?
    If it is not already loaded, you will need to first load it using the LOAD AutoLISP function.
    (load "C:\\Path\\To\\File.lsp")
    The backslashes will need to be doubled in the function call-out or replaced with a single forward slash for each. That is how AutoLISP works.
    Is the routine executable from the command line without parenthesis surrounding it? If it can be called without parenthesis, you will need to add the parenthesis in your macro.
    (c:NameOfRoutine)
    You can then combine all of that into a macro to add to a Tool Palette command.
    ^c^c(load "C:\\Path\\To\\File.lsp")(c:NameOfRoutine)
    The two ^c prefixing the macro are to escape from any currently running commands. Two escapes are typically used.
  1. Replies: 0
    Last Post: 2011-10-11, 10:00 AM
  2. 2011: Adding layouts to existing sheetset - Sheet Name
    By bjhughes in forum AutoCAD General
    Last Post: 2011-03-07, 03:12 PM
  3. Replies: 1
    Last Post: 2006-09-15, 04:16 AM
  4. Adding block to Tool Palette
    By BCrouse in forum ACA General
    Last Post: 2006-08-30, 11:31 PM
  5. Adding LSP routine to Tool Palette
    By sodeepva in forum AutoCAD General
    Last Post: 2006-03-31, 11:47 PM
