Thread: Matching layer names to a custom layer name standard when exporting Revit to dwg
    2021-12
    Lightbulb Matching layer names to a custom layer name standard when exporting Revit to dwg
    Dear all,
    Our client has a CAD standard which requires certain dwg layer names to be assigned onto certain Revit elements when exporting from Revit 2020. Please can you share your tips or recommend the tools or plugins or Dynamo Packages for this task.
    Many thanks in advance.
    in the upper right corner
    3,548
    Default Re: Matching layer names to a custom layer name standard when exporting Revit to dwg
    Quote Originally Posted by rsdesign0167798496 View Post
    Dear all,
    Congrats on your first post.
    You can create "cad export settings" which map layer names, colors, line types etc. per element for exporting.
    Save it in your template so it can be used over and over.
    The OOTB ones are based on AIA I believe.
    That's the best way to handle that if you expect to be doing that over and over.
  1. 2014: Keep layer names when exporting to DWG
    By david.ge.johansson346431 in forum Revit Architecture - General
    Last Post: 2013-05-10, 04:23 PM
  2. Replies: 12
    Last Post: 2010-01-08, 07:49 PM
  3. Replies: 3
    Last Post: 2007-03-14, 06:31 PM
  4. Change Layer names to other Layer names via a script?
    By tburke in forum AutoCAD Customization
    Last Post: 2006-12-04, 07:30 PM
  5. copy an lman from an xref into another no matching layer names
    By Hammer.John.J in forum AutoCAD Tips & Tricks
    Last Post: 2006-09-16, 08:07 AM
