Results 1 to 10 of 14
Thread: Creating "smart text" - refer to a detail number & have it change if the detail number changes
    100 Club jsr13's Avatar
    Virginia - USA
    134
    Default Creating "smart text" - refer to a detail number & have it change if the detail number changes
    What we're looking for: to have some text in a section (call it section A) that will point to another section (section B) & refer to it by section number & page, and that reference will change if Section B is relocated. Much the way that section cuts on plan will update when a section on a sheet moves/changes.
    To work correctly for us, it should be text only (no graphics or lines) and be able to add a leader. We keep calling it "smart text that contains a label" but.......
    If we had our wish, it would use the pull-down for selecting a reference section so we could select the detail we are pointing to, but we're not sure if that is possible.
    I hope I am getting my point across, but let me know if there are questions.
    Please & many thanks in advance!
    in the upper right corner
    3,548
    Default Re: Creating "smart text" - refer to a detail number & have it change if the detail number changes
    Well that sort of exists in Revit already, but not with a leader.
    We use a "View Reference" tag within text that is tied to a view on a sheet (which updates when changed)
    Not sure if that meets all your needs but it works for us.
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    468
    I heard about doing this, but how does it actually happen?
    2015-10
    468
    Quote Originally Posted by CAtDiva View Post
    Ok, so I found this as one tutorial: https://revitiq.com/adding-view-reference-text-notes/.
    2015-08
    199
    These are the 2 different ones we use at my office. One for referencing a sheet and one for a view on a sheet. The "REFER TO DWG" and "REFER TO DETAIL" is just text in the family positioned before the left justified label.
    Attachment 109021
    It would be nice to be able to add additional instance parameters into the family for text so we could write additional info instead of having to place a text note near the reference.
    Virginia - USA
    134
    View Reference! Perfect - for one of the instances I need. This is what I have come up with to use: text + label (in blue).
    Still trying to find a way to do a similar one with a leader. Anyone know how to accomplish that? The idea is to be able to point to a certain part of a detail & refer them to a detail on a different sheet.
    2015-08
    199
    Very nice, unfortunately they have not added options for leaders in view references yet so the only workaround is to use a blank text note with leader. As of Revit 2020 or 2021 (forget exactly which one) you can place a blank note.
    Attachment 109023
    2005-09
    88
    Using view references is already described, and works well for many circumstances. I don't need to add to that, but I do want to mention that the need for the ability to insert view references within text, or in a parameter (and thus into a table) is needed
    There are, I believe, a few variations of this request in the Autodesk Ideas board - it would not hurt to add more upvotes, and maybe this will finally make the roadmap
    https://forums.autodesk.com/t5/revit.../idi-p/6423681
    2015-09
    If it's just the reference + leader you need you kinda get it by using "Reference Other View" with a Callout. Won't get an arrow thought, must be an area-marking.
    And yes, being able to put view-refernces inside running text has been an request for sooo long.
    2015-11
    Revolution Design have a solution for this called "autoLink"
  1. 2017: What does the 10 lb/in^2 refer to in the results diagram and can I change it?
    By tadthurston725387 in forum Robot Structural Analysis
    Last Post: 2018-12-28, 07:31 PM
  2. Replies: 1
    Last Post: 2013-03-16, 11:35 AM
  3. Replies: 5
    Last Post: 2009-04-17, 10:10 AM
  4. How to I refer to a detail ?
    By Maximillian in forum Revit Architecture - General
    Last Post: 2007-01-16, 10:53 PM
  5. Notes that refer to drawing number on sheet
    By Archman in forum Revit Architecture - General
    Last Post: 2005-07-30, 12:46 AM
