Thread: Best Subassembly
    Raleigh, NC
    971
    Default Best Subassembly
    Best Subassembly to target an alignment at 2% grade?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,185
    Default Re: Best Subassembly
    What is the purpose? There are many subassemblies that could do this. You have BasicLane, LinkWidthAndSlope, LinkOffsetAndSlope, LinkSuperelevationAOR, and I'm certain there are many others.
    Raleigh, NC
    971
    Looks like LinkWidthandSlope is my solution.
    Can you add a subassembly to LinkWidthandSlope? In other words target the alignment then the subassemblies after keep adding to the corridor?
    I hope that question makes sense.
    2002-01
    jUSt Here (a lot)
    9,185
    Yes. That is typically how assemblies work.
  1. 2013: Best practices for tiny firm sharing Revit Central files - Best step past dropbox? VPN? Revit Server?
    By spletz240993 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-09-12, 10:49 PM
  2. import and edit built-in autodesk subassembly in subassembly composer??
    By phpa80457421 in forum AutoCAD Civil 3D - General
    Last Post: 2012-08-08, 03:57 PM
  3. subassembly Features
    Last Post: 2007-09-12, 02:27 PM
  4. Custom Subassembly?
    By coronadog in forum AutoCAD Civil 3D - Corridors
    Last Post: 2007-08-02, 01:24 PM
  5. Moving parts inside subassembly
    By chadwickt in forum Inventor - General
    Last Post: 2006-07-26, 08:47 PM
