Thread: Multi-leader Callouts
    2023-01
    67
    Default Multi-leader Callouts
    Good morning. I hope someone can help me with a text issue.
    I'm attaching a CAD file with the callouts. For some reason one of my multi-leader styles is not recognizing the text style. The circle callout is not using the correct text style. Has anyone had this happen? Any help is appreciated.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,200
    Default Re: Multi-leader Callouts
    The block used for that particular call-out is using a different style for the attribute definition in the block. Change the text style for the attribute definition in the block. Then recreate your multileader with that style should fix your issue.
    2023-01
    67
    Thank you!
  1. Count leader arrows in a multi-leader object
    Last Post: 2017-11-04, 12:37 PM
  2. Take advantage of multi-thread capabilities in multi-CPU workstations and multi-core CPU's.
    Last Post: 2012-11-21, 06:58 PM
  3. Standardized "Lasso" type leader callouts
    By jasonp in forum CAD Management - General
    Last Post: 2011-01-11, 06:14 PM
  4. multiple connection point for leader tails when using a multi-leader
    By jschraud228486 in forum AutoCAD Annotation
    Last Post: 2010-06-16, 01:42 AM
  5. Callouts within callouts
    By Mike Sealander in forum Revit Architecture - General
    Last Post: 2007-04-17, 05:17 PM
