Results 1 to 1 of 1
Thread: Dynamic, Annotative block, parts not scaling as XREF for some
    in the upper right corner
    3,525
    Unhappy Dynamic, Annotative block, parts not scaling as XREF for some
    We have a dynamic room-tag block, which is annotative, and it works great in the same drawing.
    But when xreffed, the top line (which is a multi-line attribute) does not scale properly.
    Note, this doesn't happen for everyone, some users they behave fine as expected.
    I'm hoping this is some variable or setting that I (and other users) have that we can switch.
    If anyone has a solution or ideas on things to check, I'd appreciate it.
    (I searched the Forums and didn't see a similar problem brought up that I could find)
  1. Annotative Dynamic Blocks not scaling correctly. Please help!
    By NickD22 in forum CAD Management - General
    Last Post: 2017-03-07, 01:06 PM
  2. 2013: Need some Annotative Scaling Training
    By sovby254640 in forum AutoCAD Annotation
    Last Post: 2013-08-14, 02:58 PM
  3. Dynamic Block Annotative Scaling
    By sovby254640 in forum Dynamic Blocks - Technical
    Last Post: 2012-08-16, 08:25 AM
  4. Replies: 0
    Last Post: 2008-03-12, 04:26 AM
  5. Dynamic Block scaling with Annotative text
    By .chad in forum Dynamic Blocks - Technical
    Last Post: 2007-06-15, 01:29 PM
