Thread: Does this detail component exist?
    2014-08
    Bend, OR
    11
    Default Does this detail component exist?
    Fellow travelers - can you tell me if the Detail_Items_Coursing_Lines_in-Plan.rfa actually exists in the english imperial library? It has been referred to as being in the detail items/ annotations section. My Revit does not have an annotations section under detail items. Thanks for any help.
    2001-12
    St. Louis
    5,421
    Default Re: Does this detail component exist?
    I've got 2024 installed and don't see that anywhere.
    BUT as I say that, I'm also not sure if I might have excluded libraries from my installation or not. I only work on existing buildings, so sometimes I don't bother.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    in the upper right corner
    3,548
    I have 2023 installed, but it didn't come with all the library items installed (which is problem I need to fix), so I've been loading families from my 2019 library.
    And I don't see what you're looking for in the 2019 library, but possible it exists in the 2023 libraries which I didn't get all of.
    What exactly is this item, is it for masonry?
    Sorry I couldn't help
    2013-07
    Cleveland, OH
    56
    With such a unique name, I would guess that this is something custom made - either within your firm or someone found it. Good luck
    2021-06
    Quote Originally Posted by gtepe678922 View Post
    Any luck? I was just watching a tutorial that was uploaded 3-years ago and they appear to be using RVT 2017, but the UK edition. I have never seen this family in any of my US families. After wading through the comments on the video they mention downloading the international content library from Autodesk @ from their, we can figure out the formula and adapt it to Imperial.
    Goodluck.
  1. Formula - Parameter Does Not Exist
    By phyllisr in forum Revit Architecture - Families
    Last Post: 2008-12-17, 05:56 PM
  2. Central File Does not Exist
    By jcoe in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2008-11-10, 05:11 PM
  3. Does a sum or total length feature exist?
    By khorzan in forum AutoCAD General
    Last Post: 2007-09-21, 12:54 PM
  4. File in use by others / does not exist?
    By Richard McDonald in forum AutoCAD General
    Last Post: 2006-12-08, 04:43 AM
