Re: Export bookmarks from sheet set manager
Summary: Export bookmarks from sheet set manager
Description: Hello,
I asked in Autocad forum on the Autodesk website if it's possible to export bookmarks from sheet set manager for "sheet set templates", so I could have the same structure at publish pdf that I have on Autocad. Apparently, Autocad only exports bookmarks for every single draw, but not for templates. They told me that in fact it's not possible and suggest me to write here. Thank you.
Product and Feature: AutoCAD - DWG
Submitted By: cme7689811559 on 03/08/2024
I'm not sure what you mean about "bookmarks" in SSM, are you talking about "Subsets"?
Or do you mean bookmarks of the sheets when publishing to a PDF?
If so, that is probably true, you need the sheets in the SSM to have a bookmark.
A template would not have sheets in them.
Maybe you can create a mock SSM set with dummy sheets to do what you want?
Or I probably don't understand what it is you are trying to do?
- You may not post replies
- You may not edit your posts
Forum Rules
