Thread: Sill Height Default problem
    Default Sill Height Default problem
    Hello, I have a custom window family in a upper level(right) with a sill height of 0 (si floor to ceiling window) but it shows in the level below(left) and if i put the default sill height in 0.00 it disappears from de lower level but if i use 0.90(as an example) it appears in the lower level! It doesn't make sense to me... I don't know what am i doing wrong. Please help.
    Bonus problem: When the window has a sill height of 0. two gray windows appear simulating the wall lines (does anyone know how to erase that)?
    Default Re: Sill Height Default problem
    The window family in the plan view has a masking region to simulate the window panels. I don´t know if the default sill height affects that regions maks cut plane or something...
  1. Window default sill height problem
    By CADMama in forum Revit Architecture - Families
    Last Post: 2009-08-20, 03:16 PM
  2. default sill vs default header height
    By ray salmon in forum Revit Architecture - General
    Last Post: 2009-04-19, 06:15 PM
  3. Default Sill Height in nested window family
    By noah in forum Revit Architecture - Families
    Last Post: 2005-10-05, 02:38 PM
  4. Default Sill Height in nested window family
    By noah in forum Revit Architecture - General
    Last Post: 2005-10-03, 02:29 AM
  5. Why Default Sill Height?
    By Henry D in forum Revit Architecture - General
    Last Post: 2005-03-10, 12:24 PM
