Check your attachments to find the post where that block is attached.![]()
Sometimes, i get lost in my own thoughts and need to ask directions to find my way back.
S&D DB Sharing Forum
Does this narrow it down?
[SIGPIC][/SIGPIC]
Return of the Cowbell
I can create and edit blocks in AutoCAD LT 2007, a little FYI.
Are they dynamic though?
Check out this way to do multiple viz states I have posted. Goofing around and ended up using a scale parameter. Drew a symbol at 1/4" high then did the scale parameter with a LIST. The list has two values the .25 drawn at and .0025. When that value is chosen it is only two thousandths of an inch tall which is less than the line width it is associated with so when you plot you don't see it. If you want to display you grab the grip and drag it out and visibility. Don't want to see it push it back to the tiny size and gone. I made a weld symbol with 5 different symbols all together. Now I just pick which type of weld it is and drag out the symbol. I labeled them with no plot text so you know which one you are picking. I am guessing I have a total with combinations of 40 or 50 viz states and yet there is no AutoCAD visibility state parameter in the drawing. Another dumb idea that turned out to be genius according to co-workers. They are cracking up and loving it, it is so simple and easy to do.
https://forums.augi.com/showthread.p...31#post1356631
