Thread: Is there a way to disable the sheet preview when you hover over the drawing tab?
    Raleigh, NC
    975
    Default Is there a way to disable the sheet preview when you hover over the drawing tab?
    I have an extensive set of construction plans. Each scope of work is its own DWG. i.e. Grading sheets = Grading Plans.dwg, Utility sheets = Utility Plans.dwg. As I am working every time my cursor goes up into the ribbon, AutoCAD shows me the plan views for that DWG. It is a consistent disruption.
    5,780
    Default Re: Is there a way to disable the sheet preview when you hover over the drawing tab?
    Quote Originally Posted by tim_newsome View Post
    Consider the FILETABPREVIEW sysvar.
    Consider using single-Layout sheet drawings (for plot), with a single XREF in each for that scope of work, and Layer States to control the resultant plot output.
    You do the design work in the XREF, labeling in the XREF or in the sheet (depending on how Viewports do or do not overlap, align with centerlines, etc), so the sheet drawings are just for plotting.
    Yes, it's more drawings... Yes, it can be more efficient to print them all to PDF *IF* you print via Core Console in parallel, instead of printing them via PUBLISH in series.
    HTH
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2015-10
    Alhambra
    76
    I don't know of a way to disable the sheet preview completely.
    @BlackBox referred to FILETABPREVIEW system variable.
    When you hover over the drawing tabs:
    With a 1 setting it will show thumbnails:
    With a 0 setting it will still show a list:
    - - - Updated - - -
    found this thread that provides one more system variable that will at least disable the loading of the layouts:https://forums.autodesk.com/t5/autoc...t/true#M126228
    FILETABTHUMBHOVER: controls what happens next, when you hover one of the thumbnails.. Disabling it prevents loading the modelspace or layoout you hovered over..
    So set FILETABTHUMBHOVER to 0
    in the upper right corner
    3,549
    HTH
    Yes BB, that's pretty much what our company does, and we use SSM and publish, which is awesome. We are an A/E design company and this works great for buildings and structures.
    I do know that our "Civil" C3D folks like to keep the same type of sheets in one file with multiple layouts, this helps with plan-profile data and such (at least that is what I am told), but they limit it to like 4 sheets.
    Which still works great with SSM, because you are plotting layouts from the SSM.
    5,780
    PUBLISH - regardless of using SSM or manually invoking the Command - plots drawings in series (one-at-a-time).
    Plotting via Core Console, plots multiple drawings individually in parallel (all at same time).
    As example, say it takes 30 seconds to plot a single drawing, all drawings take the same amount of time to plot, and you have 10 drawings in your plan set... PUBLISH takes +/- 300 seconds (5 mins)... Core Console takes +/- 30 seconds to achieve the same result.
    Please take from this what you like.
  1. Hover over Multifunctional Grips to stop interfering with Command Line
    Last Post: 2012-06-17, 11:47 PM
  2. Hover Over Comment Pop-up
    By SRBalliet in forum AutoCAD General
    Last Post: 2012-05-01, 03:57 PM
  3. Is there a way to disable the splash screen?
    By thomas183523 in forum NavisWorks - General
    Last Post: 2009-04-20, 05:02 PM
  4. Regenerate Catalog over and over and over
    By buzz in forum AMEP General
    Last Post: 2008-07-08, 12:55 PM
  5. Hover over Object to Display Object's Layer Name
    Last Post: 2007-05-08, 12:37 PM
