Thread: Installing ObjectARX
    2025-03
    Default Installing ObjectARX
    Where I can find a tutorial on how to install and make the first command in ObjectARX
    6,584
    Default Re: Installing ObjectARX
    Welcome to AUGI!
    I have a few questions first. ObjectARX uses C++ and has a steep learning curve. Are you sure that's what you want? If you want to program in .NET, I recommend using the C# api.
    LinkedIn
    2025-03
    I use ObjectArx long time ago with AutoCad 2015, and have lot of code done in c++, but now is different
    2023-10
    9
  1. Replies: 0
    Last Post: 2017-02-21, 07:28 PM
  2. Replies: 0
    Last Post: 2005-09-07, 06:20 AM
