Results 1 to 7 of 7
Thread: Image embedded in detail component and it just wont work...
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Default
    The attached contains a jpg swiped from one of Audi's websites. It is scaled to the right size in my component - 4833mm long - but seems to double in size when placed in a model.
    Both model and component are set to mm.
    All this debate about a scale tool and Revit finds the skills when I don't need it.
    Any thoughts?
    P
    2003-04
    London NW9
    377
    Default Re: Image embedded in detail component and it just wont work...
    I keep getting some strange errors when trying to insert it into a view
    Revit wants to close that view down
    When I look I see nothing ?
    Strange !
    Active Member LMSmith's Avatar
    2003-07
    Cambridge, MA
    67
    I'm seeing that the scale of your family view is 1:10. Inserting it into a 1:10 view in the project brings it in at the right size. Placing it in a 1:20 view doubles it. Try Import>Image if you want to adjust the size of the raster image in the project.
    2003-05
    5,153
    On the subject of strangely shrunkun cars, has anyone looked at the MX5 attached ? ( 3D Model )
    I think it came from RUGI.
    It looks to be about half the size of a VW beetle when inserted in a project.
    No idea how to scale it up.
    2003-04
    London, UK
    1,948
    Quote Originally Posted by LMSmith
    I simply cannot see the wood for the trees sometimes. Thanks.
    In the end I traced over it with about 6 splines. The exercise was to show the client that their new pride and joy would fit in the garage, I didn't need the remainder of the detail.
    Quote Originally Posted by beegee
    Grab it from the accustudio site and fiddle around with the mesh the other Autodesk product or look at importing the dxf with a scale modifier. You can't scale the rfa.
    P
    2003-05
    5,153
    Thanks Peter J,
    I'll give it a try in 3D Studio Max.
    Re importing cars from Accustudio, (you also mentioned something about that in a post in another thread ) What is the process, - can the file type be converted to rfa, or does it insert straight into the image. Is it necessary to import and path to the accustio materials ?
    2003-04
    London, UK
    1,948
    www.accustudio.com have dxf models of mesh surfaces. You should be able to download and insert into an rfa. It won't be parametric, but most of the entourage shouldn't need to be. i.e. a car don't change shape.
    Yes you'll want the materials library too.
  1. Replies: 6
    Last Post: 2011-07-07, 08:25 PM
  2. Detail Component wont show up with profile
    By mthurnauer in forum Revit Architecture - General
    Last Post: 2008-10-09, 06:11 PM
  3. Colour fills wont show through JPG image
    By Davied2 in forum Revit Architecture - General
    Last Post: 2008-01-25, 03:09 PM
  4. Detail Component with Annotation Family Embedded
    By rmcelvain.103137 in forum Revit Structure - Families
    Last Post: 2006-11-27, 05:00 PM
  5. some 5.1 families that wont work in 6.0
    By Martin P in forum Revit Architecture - General
    Last Post: 2004-02-28, 05:59 PM
