Results 1 to 10 of 20
Thread: Routine to set search paths, file names, and file locations
    45°03'55.69"N 93°27'12.21"W
    28
    Default Routine to set search paths, file names, and file locations
    Enough to be dangerous... looking for help with this lisp routine that will set these specific search paths, file names, and file locations:
    Thanks to rkmcswain for getting me started!
    (setq paths
    (apply 'strcat
    (list
    	 "\\\\Carla\\Autodesk\\Support;"
    	 "\\\\Carla\\Autodesk\\Fonts;"
    	 (getvar "ROAMABLEROOTPREFIX")
    	 "C:\\Program Files\\Autodesk Land Desktop 2007\\support;"
    	 (getvar "LOCALROOTPREFIX")
    	 "C:\\Program Files\\Autodesk Land Desktop 2007\\help;"
    	 "C:\\Program Files\\Autodesk Land Desktop 2007\\express;"
    	 "\\\\Carla\\autodesk\\Support\\Color;"
    	 "\\\\Carla\\Autodesk\\LDD 2007;"
    	 "\\\\Carla\\Autodesk\\LDD 2007\\Land;"
    	 "C:\\Program Files\\Common Files\\Autodesk Shared\\AxUi;"
    	 "C:\\Program Files\\Autodesk Land Desktop 2007\\civil;"
    	 "C:\\Program Files\\Autodesk Land Desktop 2007\\FDO\\bin;"
    	 "C:\\Program Files\\Autodesk Civil 3D 2007\\FDO\\bin;"
    	 "C:\\Program Files\\Raster Design 2007;"
    	 "C:\\Program Files\\Autodesk Land Desktop 2007\\Support\\Lisp\\Startup;"
    	 "\\\\Carla\\autodesk\ARD 2007\Help;"
    (vla-put-SupportPath
    ; Device Driver File Search Path
    (vla-put-driverspath "\\Carla\\autodesk\\Drv")
    ; Customization Files
    ; Text Editor, Dictionary, and Font File Names
    (setvar "dctcust" "\\carla\\autodesk\\support\\sample.cus")
    (setvar "fontalt" "simplex.shx")
    (setvar "fontmap" "\\carla\\autodesk\\support\\acad.fmp")
    ; Print Support File Path
    (vla-put-PrinterConfigPath "\\Carla\\Autodesk\\Plotters\\PMP Files")
    (vla-put-PrinterDescPath "\\Carla\\Autodesk\\Plotters")
    (vla-put-PrinterStyleSheetPath "\\Carla\\Autodesk\\Plot Styles")
    ; Color Book Locations
    (vla-put-ColorBookPath "\\Carla\\autodesk\\Support\\Color")
    ; Template Settings
    (vla-put-TemplateDwgPath "\\Carla\\Autodesk\\Templates")
    ; Missing Sheet Set Template File (vla-put-???????????????????? "xxx")
    (vla-put-QNewTemplateFile "\\Carla\\Autodesk\\Templates")
    (vla-put-PageSetupOverridesTemplateFile "\\Carla\\Autodesk\\Templates\\Sheet Sets\\PageOverride.dwt")
    ; Tool Palettes File Locations
    (getvar "TOOLPALETTEPATH")
    paths
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Routine to set search paths, file names, and file locations
    Quote Originally Posted by kirkm.89518
    I haven't tested this, but maybe it will lead you down the path a ways on your journey:
    (setq pref_files (vla-get-files (vla-get-preferences (vlax-get-acad-object))))
    (setq paths
    (apply 'strcat
    (list
    (getvar "ROAMABLEROOTPREFIX") ";";<--Note semicolon in red
    (getvar "LOCALROOTPREFIX") ";";<--Note semicolon in red
    (vla-put-SupportPath pref_files path)
    (vla-put-driverspath pref_files "\\Carla\\autodesk\\Drv")
    (vla-put-PrinterConfigPath pref_files "\\Carla\\Autodesk\\Plotters\\PMP Files")
    (vla-put-PrinterDescPath pref_files "\\Carla\\Autodesk\\Plotters")
    (vla-put-PrinterStyleSheetPath pref_files "\\Carla\\Autodesk\\Plot Styles")
    (vla-put-ColorBookPath pref_files "\\Carla\\autodesk\\Support\\Color")
    ; Template Settings
    (vla-put-TemplateDwgPath pref_files "\\Carla\\Autodesk\\Templates")
    (vla-put-QNewTemplateFile  pref_files "\\Carla\\Autodesk\\Templates")
    (vla-put-PageSetupOverridesTemplateFile  pref_files "\\Carla\\Autodesk\\Templates\\Sheet Sets\\PageOverride.dwt")
    ;(getvar "TOOLPALETTEPATH");  I'm not sure where you are going here...but maybe:
    (vla-put-toolpalettepath pref_files "\\Carla\\Autodesk\\Tool Palettes")
    HTH
    28
    I appreciate the help! I just tested the lisp and received the following error:
    (LOAD "//carla/autodesk/Support/acad2007test4a.lsp") ; error: ActiveX
    Server returned an error: Parameter not optional
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,174
    Try adding (vl-load-com) to the beginning of the routine.
    28
    That didn't work either, same problem:
    Command: (LOAD "//Carla/autodesk/Support/acad2007test4a.lsp") ; error: ActiveX
    Lost
    1,473
    Oops, typo:
    should be:
    (vla-put-SupportPath pref_files paths)
    There may be more; we'll just have to work through it...
    And yes, add (vl-load-com) as the first line as Opie suggested.
    28
    Well that took me to the next step, unfortunately it was another error:
    Command: (LOAD "//Carla/autodesk/Support/acad2007test4a.lsp") ; error: AutoCAD
    variable setting rejected: "fontmap" "carlaautodesksupportacad.fmp"
    ...yes acad.fmp does exist in the support folder
    2002-01
    jUSt Here (a lot)
    9,174
    Can you open this file in the VLIDE? You can then set a break point and step through the routine one step at a time to find out what is not working.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    . . ."carlaautodesksupportacad.fmp". . .
    ...hmmm something strange is going on here.
    Are AutoCAD not treating \\ in the same way anymore ?
    try single / or add drivename X: C: or . . .
    : ) Happy Computing !
    kennet
    2002-01
    jUSt Here (a lot)
    9,174
    Quote Originally Posted by kennet.sjoberg
    try single / or add driver name X: C: or . . .
    kennet
    kennet, that looks more like the forum's spell checker messing with the slashes.
  1. Trouble with Support File Search Paths
    By JGARZA0422 in forum AutoLISP
    Last Post: 2013-07-21, 03:45 PM
  2. 2012: Disappearing Support File Search Paths
    By Darren Allen in forum AutoCAD Customization
    Last Post: 2013-04-03, 04:11 PM
  3. Options and file search paths
    By KGC in forum AutoCAD Customization
    Last Post: 2008-01-08, 04:18 PM
  4. Easy way to set-up Support File Search Paths
    By joeswantek in forum AutoCAD Customization
    Last Post: 2006-07-11, 08:21 PM
