View Poll Results: Should roof by extrusion grow upwards?
Voters
23. You may not vote on this poll
  • Since roof by footprint grows upwards, it should behave the same
    20 86.96%
  • Roof by extrusion should grow downwards as currently implemented
    3 13.04%
  • I could care less and am tired of polls!
    0 0%
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Roof by Extrusion grows down?
    Count (Formula) dbaldacchino's Avatar
    2005-07
    Missouri City, Texas (Houston area)
    3,250
    Default Roof by Extrusion grows down?
    I didn't realize, but roofs by extrusion grown downwards (like a floor) instead of up, like a roof by extrusion. This seems inconsistent to me and I think it whould grow upwards. What's your take?
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: Roof by Extrusion grows down?
    There is a reason why the footprint grows upwards...and it took a while, and now I agree with it growing upward (I can now use the Top of Steel level for a roof)...and yes, I was a bit frustrated when I noticed the extrusion behaves opposite...also a bit ashamed when I was showing somebody how to do it by extrusion and told him that it would grow upward....but it didn't it grew downward :s
    Got my vote...it's too inconsistent
    Quote Originally Posted by dbaldacchino View Post
    2007-03
    Phoenix
    261
    Jinkies! Good catch. I'm with you on this needing to be fixed and behave consistently one way or the other for roofs in general, but gravity usually wins, I'd like my structure to stay put and the assembly thickness to change as it would in the field more likely than not, beams and rafters below the roof, not within the assembly.
    -LC
    2005-07
    3,250
    haha Luigi, that's when I find stuff out too, just when I'm trying to show something to someone and then look like a goober. This time I was working on modeling our house in my spare time (found some under the cushions on the couch) and was doing a round dormer with roof by extrusion and was expecting it to grow out and then figured I'll just offset the sketch. I kinda remembered that this is how it acts but at work, we seldom use the roof tool and we mainly default to the floor tool. Sometimes inconsistencies just jump out at ya
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    The reason it grows down is because you are drawing the top edge of your roof, you can't draw the bottom because then how would you change the roof end conditions. And typically with roof by extrusion you are drawing in elevations so you would be sketching the ridge to align with another ridge or something like that.
    Scott D. Brown, AIA
    BECK
    2005-07
    3,250
    Well true, but as long as you know the roof thickness, you can always offset the sketched line. I guess this is a topic that can be argued both ways. In my case, I knew what the inside dimension is (measured the dormer on the interior) so I wanted the roof to behave like the roof by footprint and grow up. It just seems inconsistent to me although I understand your argument.
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    I don't see how drawing the top or bottom has an effect on the end conditions...
    2004-06
    Memphis TN area
    7,048
    I rarely use roof by extrusion, but sure enough, EVERY time I have used it, I ALWAYS end up sketching the bottom surface (because I know where I want that to be), and then I have to offset by the roof thickness. It always happens for barrel roofs, as I know what the bottom of the roof is sitting on and its radius. Then I always have to offset upwards, and its annoying as heck if anything changes.
    2003-05
    Coast to Coast
    4,440
    Sounds like we would like the option to choose a location line for roofs, just like we'd like a location line for ceilings and floors. ie core boundary that doesn't move when we swap types.
    Scott D. Brown, AIA
    BECK
    2005-07
    3,250
    I concur, that would be nice. Basically anything built with layers could benefit from this. In the case of a roof or a ceiling, having flip arrows or something similar would just change the offset rather than mirror the object.
  1. Question: holes in a roof by extrusion
    By valerie_v1v196865 in forum Revit - Student Support
    Last Post: 2011-03-09, 04:10 PM
  2. Roof Extrusion help
    By Revitizer in forum Revit Architecture - General
    Last Post: 2010-07-29, 06:21 AM
  3. roof using extrusion
    By yoi65 in forum Revit Architecture - General
    Last Post: 2008-11-18, 10:01 PM
  4. Roof Mass & Extrusion
    By bgauthier in forum Revit Architecture - General
    Last Post: 2007-05-24, 08:37 PM
  5. Roof By Extrusion
    By dsw98 in forum Revit Architecture - General
    Last Post: 2005-12-09, 07:34 PM
