Results 1 to 8 of 8
Thread: Air Handler w/ Bottom Discharge Duct Connection
    2008-12
    San Francisco, CA
    66
    Default Air Handler w/ Bottom Discharge Duct Connection
    I am having trouble creating an Air Handler with a bottom discharge supply and return duct connection. Any ideas?
    Attached is my family
    2008-12
    San Francisco, CA
    66
    Default Re: Air Handler w/ Bottom Discharge Duct Connection
    Sorry, more detail, the problem I am having is when I insert the family into my project and try to attach a duct to the connection, the duct connects to a completely different location and does not register the system (supply or return air). I can send some screen shots if necessary.
    2007-04
    Dallas, TX
    216
    What is the reason for the solid sections by the connectors? It looks like it is a solid in a solid.
    Are you bringing the duct to the AHU or are you clicking on the AHU and extending the duct from it?
    2008-12
    San Francisco, CA
    66
    I made the solids to attached the duct connection to. I have had problems locating the duct connection anywhere but the center of the face of connection. So I made a smaller extrusion where I wanted the duct connection to be located.
    To make the duct once back in the model, I have right clicked on the connection point and selected draw duct.
    The family was created by saving-as another Air Handler family with working duct connections that were not on the bottom face of the solid. Then I deleted the old connectios and relocated them to the bottom.
    Thanks for the help.
    Neil
    2007-04
    Dallas, TX
    216
    From personnal experiece I have found that it is easier to start from scratch because then I fully understand what I am making. But that is just me. When I am making connecter in our AHU's I will have voids in the solid that are in the correct location. That way when I put the connection on the void it is the the exact location that I want. I didn't see where yours were anchored to anything besides the second solid but it looked like it might be able to move around because they weren't constrained to anything. I am no expert at all but that was what I was taught when building families. I have attached one I built a few months ago, I have seen way better though. Lastly I asked our Mechanical guy how he draws the duct around AHU's and he said he always right clicks the connector and selects "draw duct" instead of trying to bring duct to it. Hopefully some real expects will chime in soon!
    2008-12
    San Francisco, CA
    66
    Thanks for the help, I will continue to look at it as well.
    2008-12
    San Francisco, CA
    66
    Wow, I think it might have been that I was working in section view. It seems to work in plan view.
    Neil
    2008-12
    San Francisco, CA
    66
    Also, I figured out how to eliminate the extrusions for the air handler supply / return connection point. If you select the plane instead of the standard then you can move the connection point anywhere on the family face.
  1. 2013: Duct branch connection results in single line duct!
    By kevinmurtha in forum Revit MEP - General
    Last Post: 2013-01-29, 01:37 PM
  2. Moving duct connector on air handler family?
    By oshalygin in forum Revit MEP - General
    Last Post: 2009-01-19, 07:21 PM
  3. How do you connect a branch duct FROM THE BOTTOM of the main duct?
    Last Post: 2008-11-10, 09:08 PM
  4. Bottom of Duct Tag
    By martinsb21 in forum Revit MEP - General
    Last Post: 2007-06-25, 09:28 PM
  5. Piping: Top/Bottom Connection & Elbow displays
    By ameador in forum AMEP General
    Last Post: 2006-11-29, 02:13 PM
