Thread: Roof Object Hints & Tips
    2002-12
    278
    Default Roof Object Hints & Tips
    Ah great !! I can still edit this post --- updated for youtube
    Anyone in residential work should benefit from these tips, tricks and hidden secrets on the mysterious roof object. It can do more than you think it can!
    Roof Object playlist
    http://www.youtube.com/playlist?list...F&feature=plcp
    my Blog page of the same video's embedded.
    http://ausaca.blogspot.com.au/p/roof...deo-links.html
    Nothing to sell. only share!
    more to come.
    cheers
    and my original post (note; I continued to find new tricks and some of the ideas below I posted are now outdated).
    Hi to the ACA/ADT community.
    I've posted this file (ACA '07 format) for newbies and also for those into
    residential. I wanted to share what I found out whilst playing with the RO for my blog
    articles. I think it'll help alot.
    YOU CAN EDIT THE ROOF OBJECT AND ........ADD VERTICES !
    If you already knew this trick then great but it's not common knowledge.
    Why didn't you tell me?
    If you have some tricks of your own that you're prepared to share then
    please append to this post. We can help each other!
    If you are happy using slabs thats okay too. But you may learn something
    new that will help you in the sketch designing phase.
    (let me know if you want it in 04 or previous format. Of course the AEC
    items will be stuffed but all the tricks work back at least to 3.3 but
    probably ever since the roof object was introduced. You can xref in and trace
    the examples or at least follow them.
    Update>>> follow the roof label link below for corrections to even this post. No one knew what this critter could do.
    Best to ya
    www.ausaca.blogspot.com
    http://ausaca.blogspot.com/search/label/Roof
    Last edited by neje; 2012-05-01 at 02:43 PM. Reason: I was wrong!! Again - Added Youtube links
    2002-12
    278
    Default Re: Roof Object Hints & Tips
    Update: the roof object will also overlap itself, something no one appears to know that it could do including Adesk and even the creator himself. check out the posts here for how to have the RO overlap, overhang, underlap etc. Also how to cut holes in the RO.
    cheers
  1. Tips for Manufacturer Starting Commercial Roof Insulation Revit Development
    By paul930149 in forum Revit Architecture - General
    Last Post: 2012-05-10, 09:48 PM
  2. Residential Roof Object tips and Secrets
    By neje in forum ACA General
    Last Post: 2012-03-26, 02:12 PM
  3. REBAR TUTORIALS/HINTS/TIPS
    By FOUTJM in forum Revit Structure - General
    Last Post: 2007-07-11, 01:15 PM
  4. Roof soffits - soffit object or ceiling object?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2004-09-29, 08:58 PM
