Originally Posted by
lee.johnson
Is there a simpler way of changing the block text Height & width without using Block manager.
Their are just to many blocks to change and so little time to do it in
I returned here a little too late... but here is a version..."btsize" (attached) will change all nested text and mtext inside all blocks in the current drawing to specified height without exploding them...it will require you to make a regenall after using it.
and for attributes you can use edat.lsp or athht
; Allows editing of multiple attributes
; ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
; º Program: EDAT.LSP º
; º Purpose: Allows editing of multiple attributes º
; º Syntax: ed_att º
; º By: RESOLUTIONS Computer Consulting º
; º P.O. Box 1265 º
; º Sumner, WA 98390 º
; º (206) 845-2200 º
; º º
; º Date: 6/6/92, 2/17/95, 3/9/95 º
; º º
; º Revisions: º
; º 4/20/95 Added option to list the TAG names & prompts º
; º 5/31/95 Added option to change attrib Elevation º
; º 1/12/96 Removed testing statement from "*" position º
; º 3/3 /98 Oblique angle added º
; º º
; º º
; ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
(princ "\nLoading....Please wait.\n")
(defun c:edat (
;(defun c:ed_att (/ p1 p2 newval ss tag ans nr i l e fvalue pl val
; askstring ins_pt pt rot_pt r_fill ent
(defun r_fill (s len / space)
(setq space "" i (- len (strlen s)))
(substr (strcat s (repeat i (setq space (strcat space " ")))) 1 len)
(defun val (nr e) (cdr (assoc nr e)))
(defun askstring (prmpt default / str) ; ask for string
(if (null default)
(setq default "")
(princ (strcat "\n" prmpt " <" default ">: ")) ; show prompt & default value
(setq str (getstring T))
(if (= str "")
default ; not typed so return default
str ; string was typed so return it
(if (setq ss (ssget '((0 . "INSERT") (66 . 1))))
(progn
(setq tag "*")
(setq tag (strcase (askstring "Attribute TAG to edit (or ?)" tag)))
(while (= tag "?")
(textpage)
(princ "\nTAG Name Prompt")
(princ "\n-------- ------")
(setq e (entget (ssname ss 0)))
(setq ent (val -2 (tblsearch "block" (val 2 e))))
(while ent
(setq e (entget ent))
(if (= (val 0 e) "ATTDEF")
(princ (strcat "\n" (r_fill (val 2 e) 16) (val 3 e)))
(setq ent (entnext (val -1 e)))
(princ "\n")
(setq tag (strcase (askstring "Attribute TAG to edit (or ?)" "*")))
(graphscr)
(initget 1 "Color Decimals Elevation Height Layer Oblique Position Rotation Style Value")
(setq ans (getkword "\nColor/Decimals/Elevation/Height/Layer/Oblique/Position/Rotation/Style/Value: "))
(cond
((= ans "Color") (setq nr 62 newval (getint "\nNew Color Number (0 = BYBLOCK, 256 = BYLAYER): ")))
((= ans "Decimals") (setq nr 1 newval T pl (getint "\nNumber of decimal places: ")))
((= ans "Height") (setq nr 40 newval (getdist "\nNew Height: ")))
((= ans "Oblique") (setq nr 51 newval (getangle "\nNew Oblique angle: ")))
((= ans "Elevation") (setq nr 10 elev (getreal "\nNew Elevation: ")))
((= ans "Layer") (setq nr 8 newval (getstring "\nNew Layer: "))
(while (= (tblsearch ans newval) nil)
(princ (strcat "\n" (strcase newval) " not defined:"))
(setq newval (getstring "\nNew Layer: "))
((= ans "Position")(setq nr 10 p1 (getpoint "\nBase point: "))
(if p1
(setq p2 (getpoint p1 "\nNew point: ") newval T)
((= ans "Rotation")
(setq nr 50 newval (getangle "\nNew Angle: "))
(initget 1 "Attribute Block")
(setq rot_pt (getkword "\nRotate about? (Attribute/Block): "))
((= ans "Style") (setq nr 7 newval (getstring "New Style: "))
(setq newval (getstring "\nNew Style: "))
((= ans "Value") (setq nr 1 newval (getstring T "\nNew Value: ")))
(setq i 0 l (sslength ss))
(while (and newval (< i l))
(setq e (entget (ssname ss i)))
(if (and (= (val 0 e) "INSERT") (= (val 66 e) 1))
(progn
(setq ins_pt (val 10 e))
(princ ".")
(setq e (entget (entnext (val -1 e))))
(cond
((= tag "*")
(while (/= (val 0 e) "SEQEND")
(cond
((= ans "Color")
(if (null (val 62 e))
(setq e (append (list (cons 62 7)) e))
((= ans "Decimals")
(setq fvalue (atof (val 1 e)))
(if (zerop fvalue)
(setq newval (val 1 e))
(setq newval (rtos fvalue 2 pl))
((= ans "Position")
(setq newval (polar (val 10 e) (angle p1 p2) (distance p1 p2)))
; (princ newval)
; (getstring)
(setq newval (list (car (val 11 e)) (cadr (val 11 e)) elev))
(setq e (subst (cons 11 newval) (assoc 11 e) e))
(setq newval (list (car (val 10 e)) (cadr (val 10 e)) elev))
(setq e (subst (cons nr newval) (assoc nr e) e))
(entmod e)
(entupd (val -1 e))
(t (while (/= (val 0 e) "SEQEND")
(if (= tag (val 2 e))
(progn
(cond
((= ans "Color")
((= ans "Decimals")
(if (zerop fvalue)
((= ans "Position")
((= ans "Rotation")
(if (= rot_pt "Block")
(progn
(setq pt (polar ins_pt newval (distance ins_pt (val 10 e))))
(setq e (subst (cons 10 pt) (assoc 10 e) e))
(entmod e)
(entupd (val -1 e))
(setq e (entget (entnext (val -1 e)))))
(setq i (1+ i))
(princ "\nNothing selected.")
(princ "\nMultiple Attribute Edit. Version 1.3")
;;;Elise Moss
;;;Moss Designs
;;;routine locates all attributes in a drawing and allows the user to specify a new height for them
;;;December 2001
(defun c:atth (/)
(setq new-txtht
(getreal
"\nEnter new text height for all attributes in the drawing: "
(setq ss (ssget "x" (list (cons 0 "INSERT"))))
; create list of all inserts
(setq sslen (sslength ss)) ; get number of inserts
(setq index 0)
(while (< index sslen) ; while index is less than the length of ss
(progn
(setq en (ssname ss index))
(while (/= en nil) ; as long as there are entities
(setq ent-list (entget en))
(setq typ (cdr (assoc 0 ent-list)))
(while (= typ "INSERT")
(progn
(setq en (entnext en))
) ;end progn
) ; end while type = insert
(while (= typ "ATTRIB")
(progn
(setq val (cdr (assoc 1 ent-list))) ; get text value
(setq flag (cdr (assoc 70 ent-list))) ; get attribute type
(setq txtht (cdr (assoc 40 ent-list)))
; get attribute text height
(setq ent-list (subst (cons 40 new-txtht)
(cons 40 txtht)
ent-list
(entmod ent-list)
) ;end progn
) ; end while typ = attrib
); end while en /= nil
(setq index (+ index 1))
) ; end progn
) ; end while index < sslen
(command "regen")
) ; end defun
(prompt "\nType 'atth' to change the height of all attributes in the drawing. ")
