How do I save my dwg as a pdf file?
The only way I know is to print to a PDF Printer like PDF Creator or Bluebeam.
When I create a pdf in acad 07 it puts the paper size and pdf file suffix twicw.
how do I stop this?
You can also use a third-party software like Slick! PdfPlus which also does batch conversion. You can download a demo from www.slickwin.com/slickpdfplusdownload.html.
i pick DWG to PDF in the printer / ploter selection area in the plot model dialog box.
when i hit print, i am promopted to path it to where i want it saved.
it automaticly uses the file name that i have it saved as
but it adds the paper size dimmensions + .pdf.
when i hit save the file name looks this,
"filenamre"-"papersize".pdf.pdf
Is it actually adding the name of your viewport? Is your viewport labeled as your paper size?
i don't name the viewports, howerver the drawing tabs are broke up into sheet sizes.
not sure why it would pull info from that though?
