Hi
I am using acad2004. I was testing the 3rd party softarel xl2cad now I do not have the expressmenu. I tried to type expressmenu at the command propmt but it was a unknown command. Could you help me to get the express tools back.
MK
Hi
MK
expresstools? (at the command prompt)Originally Posted by minhtct
or try menuload...
Espresstools is also an unknown command. I belive the 3rd party software modify the menu path settings in acad.
Hi Mike Perry
Could you share some advice to us?
Thanks
MK
If that's the case, can you not go to Tools\Options\Files and re-modify the paths?Originally Posted by minhtct
BTW and just in case, eSpresstools will be an unknown command. Make sure you typed eXpresstools.
If you type MENULOAD, is EXPRESS listed?
After installing the software, there was a new tool bar for that application. I then decide not to used the software, and uninstall it. The Express menu was still there but none of it command worked. I then reload the acad.mns and express menu disappear. Now I cannot reload the express menu.
MK
Make sure the path to your Express Tools is in your support file search path.Originally Posted by minhtct
This will be something like C:\Program Files\AutoCAD 2004\Express
After you add this, close AutoCAD and reopen it. Check to make sure the path is still there, then try the EXPRESSMENU and/or EXPRESSTOOLS command.
If you are forced to use ._MENULOAD to load the menu, then something is wrong anyway.
BTW: We have XL2CAD and it's never messed up our Express Tools or support paths.
R.K. McSwain | CAD Panacea |
HiOriginally Posted by minhtct
Have you browsed / (re)viewed the information presented in THIS post, found in the AutoCAD FAQ (Read only) forum...
Have a good one, Mike
Hi
Thanks for your helps. It was the path problem. I did not check under "support files search path". I only check the menu path. Somehow the path in "Support file search path" was altered it only read "C:Program File". The rest of the line was missing. I modified it and it is now working.
Again, thanks for all your responses.
MK
