Thread: Tool palette groups
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Default Tool palette groups
    Hello,
    I'm looking for a lisp that will switch between my difference tool palette groups.
    Group names: Demo, Const, Pltng, etc.
    Also does any one have or has the able to write a reactor that if the drawing file name starts with the following file name:
    LC- it would switch to my Construction group, if LP- it would switch to my Planting group, etc.?
    Thanks.
    6,409
    Default Re: Tool palette groups
    You can change your palette groups with workspaces. That's what they were designed for.
    LinkedIn
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    If going with the WorkSpace change to set the desired tool palette group, you can get a list of workspaces using this routine. The attached file will need to have the file extension renamed to ".lsp" after you download it.
    Once you have the available workspaces, you can use this routine to set the current workspace system variable as desired.
  1. Replies: 0
    Last Post: 2011-10-11, 10:00 AM
  2. ADT, ABS and Civil 3D - Distributing tool palette groups to everyone
    By Dave Lewis in forum AutoCAD Customization
    Last Post: 2007-02-01, 07:14 PM
  3. AutoCAD 2005 - How to transfer tool palette groups
    By Buffeldrek in forum AutoCAD Customization
    Last Post: 2006-08-08, 09:05 AM
  4. TOOL PALETTE GROUPS
    By gdaniels in forum ACA General
    Last Post: 2005-05-19, 08:50 AM
  5. Can Tool Palette "Groups" be shared?
    By bpayne in forum AutoCAD General
    Last Post: 2004-08-26, 09:03 PM
