Results 1 to 8 of 8
Thread: Images in Pull Down Menus
    I could stop if I wanted to lmitsou's Avatar
    2003-01
    UK
    219
    Exclamation Images in Pull Down Menus
    Hi all,
    I am trying to add images to my pull down menus, because I would like instead of seeing just the name of the pull down menu (i.e. File, Edit, Insert, etc.) to be able to see an image as well. I want to do that with some custom menus I created. I use AutoCAD 2006.
    Any help would be much appreciated.
    Loukas Mitsou
    2004-07
    Detroit Michigan
    2,508
    Default Re: Images in Pull Down Menus
    While in the cui you can add images to menu items by selecting the item from the menu tree.
    For example:
    Open the cui and go to menu, file, and then the close command.
    In the right pane, you should see options for selecting an image or creating one from scratch.
    13,656
    Hi Loukas
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    2003-01
    UK
    219
    Quote Originally Posted by Mike.Perry
    Hi Loukas
    Thanks, Mike
    Forum Moderator
    Hi Mike,
    Can you please let me know the location of the thread? I can't see it written on your message.
    Thanks, Loukas Mitsou
    2003-01
    UK
    219
    Hi Robert,
    Thank you for your reply and your help. I assume that you are talking about button images, am I right? If I am, what I am asking for is a bit different. I want the menu itself to have an image. Before you open it and see all the commands and buttons. Like for example, when you first start AutoCAD you see all the pull down menus File, Edit, View, etc. These are plain text. I would like to have an image instead of plain text.
    Thanks for your help.
    Loukas Mitsou
    13,656
    Quote Originally Posted by lmitsou
    Hi Loukas
    Sorry, I am a little confused seeing as you have just posted the above question in the actual thread ( new location ).
    AUGI Forums > General Design > AutoCAD > AutoCAD Support > AutoCAD 2006 > AutoCAD 2006 CUI Menus > Images in Pull Down Menus
    Mike
    2003-01
    UK
    219
    Mike, please ignore my previous message. It's first thing in the morning here and no coffee yet!!!
    13,656
    Smile Re: Images in Pull Down Menus
    Hi Loukas
    Ok! and please go get yourself some coffee
    Mike
  1. Double Pull Down Menus?
    By djamison in forum AutoCAD Customization
    Last Post: 2009-06-09, 04:43 PM
  2. pull-down menus disappeared
    By Maverick91 in forum AutoCAD General
    Last Post: 2008-08-11, 06:37 PM
  3. Pull down Menus
    By cbernier01 in forum AutoCAD Fields
    Last Post: 2008-01-09, 03:09 PM
  4. Add in missing pull-down menus
    By joel.57674 in forum AutoCAD Customization
    Last Post: 2006-04-01, 12:59 AM
  5. Reloading pull down menus
    By kschultz in forum AutoCAD CUI Menus
    Last Post: 2005-10-04, 03:23 PM
