Results 1 to 10 of 15
Thread: Logitech mouse and CAD
    2002-12
    5
    Default Logitech mouse and CAD
    HELP!!!! I have just upgraded from AutoCAD 2000i to 2005. It seems good so far! There are a number of changes, some good and some bad. One thats seem bad is the way relatime zoom and pan now work with a wheel mouse. I have an Logitech click optical mouse and the following things seem to occure:
    zoom percentage is a lot more than in previous versions (I know how to adjust this)
    double clicking the wheel button no longer activates the zoom extents function
    and finally pan only seems to work accross the horizontal???
    Can anyone one tell me why?
    Paul
    Wink Re: Logitech mouse and CAD
    Have you tried the options in the control panel for the mouse?
    13,656
    Default Re: Logitech mouse and CAD
    Hi
    Have a browse of the following threads (especially take note of any links within) -
    Zoom Scroll stops on its own
    mbuttonpan variable
    Scroll Button Pan is Wacky!
    panning with mouse wheel
    Middle Button OSNAP?
    Middle Button option on mice?????
    Short Cut (Right Click) Menu
    Right-Click doesn't work
    Have you tried searching the Forums, you will find a lot of additional information on this subject -
    Search Forums
    Have a good one, Mike
    I could stop if I wanted to JASONM30395's Avatar
    2002-04
    Halifax NS Canada
    397
    MS office compatible needs to be selected
    Loyalty above all else except honor
    For my honor is my life!
    2002-12
    5
    Thanks for the help people - I can now pan and zoom however, its not pan realtime?!?! is more of a scroll?!?!?
    Is there any way of setting the middle button to be pan realtime?
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    Sounds a bit like when I first installed my logitech mouse, set your middle button to the middle button function, rather than wheel, and of course, make sure you have the right driver installed.
    Hope that helps
    Kathy
    100 Club tbarnesarc's Avatar
    2004-07
    Laguna Beach, CA
    186
    Clicking Middle scroll wheel used to give you OSnap. Now you can get that with CTR Right Click. Maybe that will help as well getting used to 2005. I had the same problems at first.
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    564
    Quote Originally Posted by taylor.71590
    Mine still does in 05
    100 Club Spectrefish's Avatar
    2004-08
    Earth
    183
    Quote Originally Posted by Pdurbo
    Do you have the middle button on the mouse set to the function "middle button" in your logitech software? Is there software for your mouse?
    Also, turn off the scroll bars in the AutoCAD window. Tools/Options/ display tab/ window elements...uncheck the box that says "display the scroll bars........". This may help it to pan realtime.
    Member ramon.80175's Avatar
    2004-12
    Ladera Ranch, CA
    3
    The way I fixed this problem is to uninstall the Logitech drivers. If you just use the default Microsoft driver, the real-time pan and zoom will work. Worked for me every time. You dont get all the advantages of the Logitech software, but thats nothing if can't real-time pan and zoom.
  1. Logitech Performance MX Mouse
    By derek.96018 in forum Hardware
    Last Post: 2016-06-30, 09:02 PM
  2. Logitech V450 Mouse
    By Denis01 in forum Revit - Hardware & Operating Systems
    Last Post: 2010-01-23, 12:21 AM
  3. Wireless Logitech Mouse
    By rhayes.99001 in forum ACA General
    Last Post: 2007-04-21, 02:18 AM
  4. Anybody using the Logitech Mx 700 mouse
    By Eric Stewart in forum Revit - Hardware & Operating Systems
    Last Post: 2005-04-07, 04:46 PM
  5. mx10 Logitech Mouse
    By robert.1.hall72202 in forum Hardware
    Last Post: 2004-11-29, 05:26 PM
