Anyone know if these commands are in MEP 2012?
Thanks, is this something that I can still do, after installlation is completed?
You sure can. Insert the installation disc and through the Add/Remove programs feature, you can run through the installation selections when it asks you to customize the installation. From there you can check the box that will install the E.T.'s
