Summary: The ability to convert MTEXT into a MULTILEADER.
Description: I would like to be able to convert mtext to a multileader by using the "ADD LEADER" button.
How Used: Sometimes you have text that needs moved to a location that will require a leader where it didn't before. If you are using multileaders then you would need to re-type (or cut and paste) the text into the new multileader. It would save a lot of time if you could use the "ADD LEADER" command for multileaders to convert the text to a multileader.
Feature Affinity: MText
Submitted By: Brad Sanada on April 30, 2008
