Thread: Quantity column in schedules
    2006-12
    Big "D"
    3,711
    Default Quantity column in schedules
    Can someone please tell me how to do a quantities column for my schedules?
    I can't find anything on how to do it. And I can't find it in Revit. I tried the grand totals, but that puts in headers and splits the schedule into groups. That's not what I'm looking for.
    If I have 4 pieces of the same equipment, I'd like it listed once, with the quantity shown as 4.
    2005-12
    San Luis Obispo, CA
    285
    Default Re: Quantity column in schedules
    Quote Originally Posted by dzatto View Post
    in Sorting/Grouping sort by the equipment type, check the footer box, check the Grand Totals box, and uncheck the Itemize every Instance box. Should then look something like the attached.
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by Dave Jones DDP View Post
    That's closer. I was wanting an actual column instead of a footer. I guess I'm still used to how it looks in "that other program".
    2005-12
    San Luis Obispo, CA
    285
    Its taken me a bit of time to get used to having the line item quantities one space down from where it's supposed to be. Having had to count glass lites and alum panels manually for years and years I'm just so glad that it's automated now I don't care where the quantity is
    Certifiable AUGI Addict twiceroadsfool's Avatar
    2006-01
    4,516
    I dont waste time doing it, since im fine with the footer, but if you want to do a LITTLE extra leg work:
    Make a type property called "Count" and in the families themselves, set the formula side equal to 1. (That means for all new family types itll be 1 as well).
    Then in the schedule format, make Count a field that will calculate totals, and unitemize every instance.
    Done.
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by twiceroadsfool View Post
    Done.
    See, I keep telling people you are good for something!
    I was thinking that there has to be a way to set a property and use a formula, and there it is.
  1. 2014: Column schedules
    By cmbyrd414656 in forum Revit Structure - General
    Last Post: 2014-10-03, 09:06 AM
  2. Column Schedules
    By Mr Greg in forum Revit Structure - General
    Last Post: 2007-12-04, 08:36 PM
  3. Replies: 12
    Last Post: 2006-11-14, 11:03 AM
  4. 'graphical' column schedules
    By john.hainsworth in forum Revit Structure - General
    Last Post: 2006-02-17, 10:58 PM
  5. Column & Beam Schedules
    By barathd in forum Revit Architecture - General
    Last Post: 2005-08-10, 03:58 PM
