Thread: Plot a Custom Title Block from Sheet Set Manager
    2005-02
    7
    Post Plot a Custom Title Block from Sheet Set Manager
    I'm trying to add a custom title block. When I select it in the Sheet set manager I get this message "The selected file does not contain any initialized layouts" Does anyone know a way around this?
    Also I keep getting the error message "WARNING: Incompatible or missing plot style"
    13,656
    Default Re: Plot a Custom Title Block from Sheet Set Manager
    Hi
    Quote Originally Posted by luke.siebert
    Can all AutoCAD Plot files / settings be found / resolved?
    What happens if you first apply a (working) Page Setup to the Layout(s)?
    Have a browse through the below results obtained via an Autodesk Discussion Groups "All AutoCAD Groups" search -
    "WARNING: Incompatible or missing plot style" - 3 results
    Have a good one, Mike
    2005-02
    7
    The Problem Exists in ADT 2005, everything seems to be found and resolved. I figured out the print warning, but I still cannot use my custom title block. I've attached the file. Maybe someone could take a look and tell me what's wrong w/ it. At the same time, I have our school logo on it. The logo is an OLE object and will not print.
    13,656
    Hi
    Have a browse through the following threads -
    Plotting OLE Objects
    How Do You Get These &%$#+@^# OLE's To Plot ???
    inserting Excel file
    Personally I think the OLE Object within your drawing frame has become corrupt, try deleting it, then re-creating it.
    A Search of the Forums could well be worth your time, below are a few example search strings to try -
    *OLE* + *Plot*
    or
    *OLE* + *Print*
    or
    *OLE + *Select*
  1. Replies: 1
    Last Post: 2014-11-20, 12:27 AM
  2. Setting up Fields within drawing title block and linking to Sheet Set Manager
    By levans138199 in forum AutoCAD Sheet Set Manager
    Last Post: 2012-10-08, 07:33 PM
  3. Current Sheet (Set) Custom in Sheet Set Manager
    By Havoc501 in forum AutoCAD Fields
    Last Post: 2012-10-04, 03:41 PM
  4. Replies: 1
    Last Post: 2007-01-07, 10:08 AM
  5. Title Sheet using Sheet Set Manager
    By rklee in forum AutoCAD Sheet Set Manager
    Last Post: 2005-02-21, 05:00 PM
