Has anyone ran into a problem printing a drawing with an OLE file embedded? When using Multi-batch, I keep getting black boxes instead of the table I've inserted. I am using 2007 LT, 2007Excel, Multi-batch 8.0...
Scott
Scott
Hi
For starters, you may wish to browse / review the information found in the following thread...
OLE (eg Excel) Objects within drawing file not Plotting correctly
Have a good one, Mike
Thanks. I think I read all of those before posting though
I think it is a Multi-Batch problem. I can print correctly through the Autocad plot menu. It's when I send the entire set with Multi-Batch that I get the black boxes.
I keep getting black boxes when i try to plot an ole object to a dwf either through publishing or plotting.
Has anyone ever found a solution to this one? I am having the same problem, (Excel files printing as black boxes).
I would check the properties of the OLE. Just right click on the OLE to view the properties optin. Then look in the Misc. catagory for the plot quality. Make sure it is on Monochrome.
That was it!, Thaks alot for the help.
