Thread: Manipulating dwgname variable in diesel field expression
    2015-09
    Vancouver
    12
    Default Manipulating dwgname variable in diesel field expression
    I have (with help from others) come up with a few diesel expressions I use in my borders. Both expressions grab data from the dwgname to populate attributes within my border.
    Typical drawing number
    07028-18D-34-030-RA.dwg
    The first grabs the first 16 characters (our drawing number) and places in the drawing number attribute.
    $(substr,$(getvar,dwgname),1,16)
    The second grabs only the 4th from the end character (our revision) and places in the drawing revision attribute.
    $(substr, $(getvar, dwgname),$(-,$(strlen, $(getvar, dwgname)),4),1)
    The third grabs only a portion out of the middle of the border (34) that we use for our area number.
    $(substr,$(getvar,dwgname),11,2)
    What I am having trouble with is finding a way (within diesel) to grab everything but the last 7 characters. In my example it would return the same value as my first example. However, sometimes our drawing number lengths differ and it would make sense to work from the end of the file to the front because the "-RA.dwg" will always be constant.
    Any help is appreicated and I hope the 3 expressions I've listed are useful to other users.
    ..g
    elea.lsp
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: Manipulating dwgname variable in diesel field expression
    Quote Originally Posted by gjp View Post
    Use this expression
    $(substr,$(getvar,DWGNAME),1,$(-,$(strlen,$(getvar,DWGNAME)),7))
    2006-09
    8
    this is really great!
    how about making this expression with results upper case?
    in the upper right corner
    3,507
    Quote Originally Posted by kheajohn View Post
    Try this:
    $(UPPER,$(SUBSTR,$(getvar,DWGNAME),1,$(-,$(strlen,$(getvar,DWGNAME)),7))
    I stole from this thread
    2006-09
    8
    Try this:
    __________________
    Ted
    Those who master others have Force.
    Those who master themselves have Strength.
    i tried this before and does'nt work. Thanks.....anyone?
    Tallahassee, FL USA
    3,665
    Try this:
    Appears to be missing a closing parentheses at the end.
  1. 2014: CUI Macro with Diesel Expression
    By ccarlson376355 in forum AutoCAD Customization
    Last Post: 2013-06-10, 08:39 PM
  2. Comparing tab name with expression in diesel
    By Phil Gravel in forum AutoCAD Customization
    Last Post: 2012-10-31, 07:46 PM
  3. Using a Diesel expression in a macro
    By barker_anthony in forum AutoCAD Customization
    Last Post: 2010-10-28, 06:16 PM
  4. Backslash in DIESEL expression?
    By christopherd in forum AutoCAD Customization
    Last Post: 2007-11-16, 08:17 AM
