Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Sheet Set w/ a Multi-line Field
  1. #11
    9,805
    Default Re: Sheet Set w/ a Multi-line Field
    It doesn't matter -- unless you are willing to lose control of where the line breaks happen in your sheet titles. I can't.....
    RAND ROAD
    PLAN AND PROFILE
    STA.1 570+27.00 to STA 1890+23.00
    works,
    RAND ROAD PLAN
    AND PROFILE STA.
    1570+27.00 to STA 1890+23.00
    doesn't
    SSM and fields have been around almost 10 years.
    Still waiting on this feature.....
  2. #12
    Cairo - no, not Illinois
    5,069
    and what's really frustrating? Fields will recognize line breaks if the source is the comments in DWGPROPS.
  3. #13
    9,805
    And even more frustrating...? This could probably be fixed by the proper programmer in 1/2 hour and included in the next SP.
    I predict we'll never see it though.
  4. #14
    2012-09
    Unhappy Re: Sheet Set w/ a Multi-line Field
    WHEN is this going to be added? It seems that everyone has just given up. Come on Autodesk! As pointed out you already support line breaks in the DWGPROPS! Please get to this. Manually generating a drawing index for everyone of our projects because we are unable to have a single field for the drawing title is frustrating.
  5. #15
    2010-07
    5
    Possible work around:
    Use "non-breaking spaces" where you want a space between words and use a "space" where you want a new line. Insert teh field in MTEXT and adjust teh width.
    (Non beakinf space = ALT+0160, select for symbol, copy from character map, etc.)
    This_is_the_First_Line The_Second_Line The_Third_Line ("_" indicates non-breaking space.)
    ^space ^ space
    This is the First Line
    The Second Line
    The Third Line
  1. Custom Field - Sheet 1 of 31, Sheet 2 of 31, etc
    By jeepinaround in forum AutoCAD Fields
    Last Post: 2018-06-14, 09:30 PM
  2. Is there a way to format a field for multi-line?
    By dfarris75 in forum AutoCAD Fields
    Last Post: 2017-11-27, 09:33 AM
  3. Linefeed override in multi-line attribute with field
    By JaCAD in forum AutoCAD Fields
    Last Post: 2011-05-23, 11:57 AM
  4. Multi sheet plotting in Sheet set manager
    By tim.ashton in forum AutoCAD Plotting
    Last Post: 2007-01-27, 02:00 PM
  5. Multi line sheet title
    By vservello in forum AutoCAD Sheet Set Manager
    Last Post: 2005-05-26, 08:34 PM
