Thread: DWG with OLE crashes when plotted via a PC3 file
    2005-02
    54
    Question DWG with OLE crashes when plotted via a PC3 file
    I have a problem plotting drawings with OLE's in it. I have check for an up to dated plotter driver for a Oce TDS600. For some reason when I use a PC3 file to plot drawings, I crash. The work away that i found is to use the windows system printer to plot out my drawings. Any reasons why I crash when using a PC3 file?
    13,656
    Default Re: DWG with OLE crashes when plotted via a PC3 file
    Hi "kschultz" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    13,656
    Hi
    For starters take a browse of the following thread in the AutoCAD FAQ (Read only) forum...
    OLE (eg Excel) Objects within drawing file not Plotting correctly
    Have a good one, Mike
    13,656
    Question Re: DWG with OLE crashes when plotted via a PC3 file
    Quote Originally Posted by kschultz
    Hi
    Taking the same DWG file ( with OLE Object ) does it Plot ok! on other output devices eg
    Non Oce machines.
  1. AutoCAD crashes while inserting .ATC File
    By asutherland in forum AutoCAD Civil 3D - General
    Last Post: 2011-07-14, 06:36 PM
  2. Explorer Crashes on Revit File
    By mlynch in forum Revit Structure - General
    Last Post: 2010-07-06, 01:01 PM
  3. DR 2011 crashes when opening DWG file
    By Mike Y in forum Design Review - General
    Last Post: 2010-06-22, 05:48 PM
  4. Revit Crashes - Locks File
    By cek in forum Revit Architecture - General
    Last Post: 2010-04-28, 10:09 AM
  5. Revit crashes after trying to open bad file
    By CBroda in forum Revit Architecture - General
    Last Post: 2008-02-02, 07:54 PM
