Recently I used AutoCAD 2005 since last month and everything was fine till I got drawing file from my client, a dwg AutoCAD2000 format, and did some revision to the drawing. I changed the hatch color to yellow, the original is blue, and saved the file to AutoCAD 2000 format since my client use AutoCAD 2000. After the file is closed and reopen, the program seemed to be hanged and not responding. When I try to open the error file in other computer, with higher specification, it’s still take a long time to open. After a few minutes, it opens but the hatch scale is to be change in some area. Trying fix the problem with match properties doesn't help. What’s happening? Is this caused by save the file as AutoCAD 2000 format or anything else?
Additional information, my PC use P 4 2,4 GHz, 256 M RAM, HDD 40 G. No other program installed on this PC.I attach the native file and the error one. Thx
