Thread: AutoCAD loading "junk"
    AUGI Director cadpoobah's Avatar
    2015-09
    Central Ohio
    437
    Default AutoCAD loading "junk"
    When I open or insert some drawings, I see this:
    Loading AEC Base...
    Loading AEC Project Base...
    Loading AEC Schedule Data...
    Loading AEC Architectural Base...
    Loading ABS Base...
    Loading Modeler DLLs.
    I am running straight AutoCAD. The drawing I'm opening is a 2D detail, not generated in ADT or ABS. So, why is it loading all this junk? It takes forever (relatively speaking, of course!).
    Can this info be "purged"? Is it tied to certain objects? Can I find out which objects?
    Thanks.
    I could stop if I wanted to JASONM30395's Avatar
    2002-04
    Halifax NS Canada
    397
    Default Re: AutoCAD loading "junk"
    Are there any blocks in the drawing that were created in ADT?
    Loyalty above all else except honor
    For my honor is my life!
    13,657
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS68773 - Proxy warnings about AECARCHBASE.* and AEC*.* files
    ID: TS79478 - Save as R12 DXF format from AutoCAD®
    Maybe take a look at the Command Line version of Purge -
    Command: ._-Purge
    Enter type of unused objects to purge
    [Blocks/Dimstyles/LAyers/LTypes/Plotstyles/SHapes/textSTyles/Mlinestyles/Tablestyles/Regapps/All]:
    AutoCAD Layer Filter and APP ID Purge Tool
    Have a good one, Mike
  1. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  2. Navisworks 2010 Manage Error Loading NWF "Contents Are Corrupt"
    By mdlamarra in forum NavisWorks - General
    Last Post: 2009-10-01, 05:21 PM
  3. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-01, 04:21 AM
  4. Replies: 2
    Last Post: 2008-11-17, 02:17 PM
  5. Replies: 13
    Last Post: 2006-05-25, 09:32 PM
