Results 1 to 6 of 6
Thread: Acad.pgp Shortcuts with Scandinavian letters å ä ö not recognized by AutoCAD
    Active Member tuomo.jarvinen's Avatar
    2015-09
    Jyväskylä, Finland
    54
    Default Acad.pgp Shortcuts with Scandinavian letters å ä ö not recognized by AutoCAD
    Hi,
    I got a new laptop. Installed AutoCAD Civil3D 2019. In acad.pgp I have following shortcuts:
    Å, *ISOLATEOBJECTS
    Ö, *HIDEOBJECTS
    Ä, *UNISOLATEOBJECTS
    All the other shortcuts work, but these above are ignored. They are not recognized. Any idea, where the problem might be?
    I have used acad.pgp custom - defined shortcuts for years with no problem.
    2015-09
    Jyväskylä, Finland
    54
    3
    Default Re: Acad.pgp Shortcuts with Scandinavian letters å ä ö not recognized by AutoCAD
    Solution found: When saving Your acad.pgp with Notepad, use ANSI - encoding. I had it UTF-8. After saving it with ANSI-encoding, it works fine.
    2005-06
    in the upper right corner
    3,550
    Quote Originally Posted by tuomo.jarvinen View Post
    Not that I will ever use Scandinavian characters in my pgp file, thanks for posting the solution!
    2015-09
    Jyväskylä, Finland
    54
    2015-09
    Jyväskylä, Finland
    54
    3
    Update: After upgrading to Windows 11, I noticed that AutoCAD’s acad.pgp file, when saved as a txt file using Notepad, was being automatically converted from ANSI to UTF-8. This caused Scandinavian characters (å, ä, ö) in my command shortcuts again to become unrecognized by AutoCAD. Here’s how I resolved it:
    I downloaded the portable version of Notepad++ (no admin rights needed) from its official site and used it to open and edit acad.pgp. I manually re-added the missing å, ä, and ö characters, then saved the file explicitly in ANSI encoding. After running the REINIT command in AutoCAD to update the .pgp file, my shortcuts with Scandinavian letters worked perfectly again.
    For anyone facing similar issues, ensure you save in ANSI encoding using a tool like Notepad++ and reapply the changes in AutoCAD with REINIT. Works again!
    Turlock, CA
    6,605
    Good work. Thanks for sharing your solution.
    C:> ED WORKING....
    LinkedIn
  1. 2015: XL alias for XLINE not working according to Acad.pgp
    By Danty in forum AutoCAD General
    Last Post: 2016-01-25, 01:47 PM
  2. AutoCAD LT 2007 - Changing keyboard commands in Acad.pgp file
    By son.do in forum AutoCAD LT - General
    Last Post: 2009-04-07, 03:04 PM
  3. Personal pgp vs office pgp
    By dalewww in forum CAD Management - General
    Last Post: 2008-06-01, 11:17 AM
  4. Alias within Acad.pgp file not working
    By ddriscoll in forum AutoCAD General
    Last Post: 2007-05-23, 05:15 PM
  5. Replies: 8
    Last Post: 2007-04-20, 08:48 PM
Tags for this Thread
